48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. sathish D C
    Gingerbread Apr 27, 2017
  2. jhalayashraj
    Honeycomb Apr 28, 2017
    jhalayashraj , Apr 28, 2017 :
    Thanks mate.
  3. rsennat
    Donut Apr 30, 2017
    rsennat , Apr 30, 2017 :
    @jhalayashraj and others, I clean flashed from LegendROM 9.0 to 15.0. I installed open_gapps-arm-7.1-pico-20161104.zip.
    After this, I keep getting Setup Wizard has stopped on boot up, when it asks to "Copy your data" or "Fresh start".
    Need help on recovering my phone.. please.
  4. jhalayashraj
    Honeycomb Apr 30, 2017
    jhalayashraj , Apr 30, 2017 :
    Its because you flashed older gapps you need to flash latest gapps for now you can do this:-
    Flash ROM
    Boot into ROM
    Flash gapps.
    G_Rohan_Patre_hiZT likes this.
  5. Tarfex
    Ice Cream Sandwich Apr 30, 2017
    Tarfex , Apr 30, 2017 :
    try flashing the slim 7.1.2 Gapps they work for me
    ziepicwaffle likes this.
  6. rsennat
    Donut Apr 30, 2017
  7. jhalayashraj
    Honeycomb May 12, 2017
  8. ElRobertson
    Gingerbread May 13, 2017
    ElRobertson , May 13, 2017 :
    Hey can you look into the power off alarm problem? This was working in CM13 but no longer in CM14 based ROMs.
    When activating an alarm and power off, the phone boots 2min before the alarm but it stays in boot loop.
    When the USB adapter is plugged in, the phone boots. So there must be something wrong in the code.
  9. jhalayashraj
    Honeycomb May 13, 2017
    jhalayashraj , May 13, 2017 :
    This bug is already reported on LineageOs JIRA but they rejected it by saying "They can't fix it as google removed it from android N" people are commenting same USB plugged in thing but they are seems to ignore all that.
    Lineage JIRA :- https://jira.lineageos.org/browse/BUGBASH-46
  10. ElRobertson
    I know! they are ignoring us. !!! I was hoping maybe you can help! :)
  11. jhalayashraj
    Honeycomb May 14, 2017
    jhalayashraj , May 14, 2017 :
    I tried but didn't find the problem. I will keep looking into it.
    ElRobertson likes this.
  12. ElRobertson
    Gingerbread May 15, 2017
    ElRobertson , May 15, 2017 :
    Thank you very much!
  13. jhalayashraj
    Honeycomb May 15, 2017
  14. adi_daga
  15. jhalayashraj
  16. tomasvanhamond
    Cupcake May 17, 2017
    tomasvanhamond , May 17, 2017 :
    After I flashed the magisk zip. My OPO stays in bootloop... How come? Any fixes?
    Edit: After flashing LegendROM v15.0 again, my OPO rebooted normally.
  17. jhalayashraj
    Honeycomb May 17, 2017
    jhalayashraj , May 17, 2017 :
    Next time Only Flash Magisk zip not superSu with it.
    tomasvanhamond likes this.
  18. jhalayashraj
    UPDATE:- 16.0
    Changes:-
    Android-7.1.2_r8 Merged
    • Dark Theme Added (Experimental)
    • AptX Codec Support Added
    • Fixed Compatibility with Custom Battery Icons Of Some Themes
    • Recents Memory Bar Improved
    • Fixed WiFi QS in The Off State while Entering The Detail View
    • Improved Scrolling For TaskManager list
    • Ambient Display is Turned Off By default
    • Trebuchet Added Back
    • CustomTiles Removed
    Legend Browser - v59.0.3071.2814652 Added
    • DuckDuckGo Search Engine Added
    • Malware Domains Filter Added
    • Privacy Filter Added
    • Ad Filter Added
    Kernel:-
    • Disabled MPDecision By Default
    • Smartmax And Smartmax_eps(extreme power saving) Governor Added
    • Cpufreq: Interactive Governor Tweaked
    • Optimization Flags for Better Performance Added
    • Cpuquiet Added
    • Cpufreq: cpu-boost: Don't Boost Over User Set Max Freq
    • Added Fsync on/off Support
    So many changes on kernel side do checkout the
    Changelog:- https://drive.google.com/file/d/0B1ElV3wFA2krQTVNZlRFc3Bjbmc/view
    Download:- https://www.androidfilehost.com/?fid=745425885120732489
    Clean Flash is recommended for everyone.
    Do remember Dark Theme is still Experimental also it will restart systemui if you are rooted if you are not thn you need to manually restart systemui or reboot.
    Do not apply substratum Theme over Dark Theme If you want to use substratum Theme just apply it over light Theme.
    If you guys like my work you can donate me As I spend a lot of time and effort working on this.
    Cheers.
    Happy Flashing.
  19. jhalayashraj
    silverview, adi_daga and ziepicwaffle like this.
  20. se7enlyn
    Ice Cream Sandwich May 20, 2017
    daniga74 and ziepicwaffle like this.
