48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. jhalayashraj
    Honeycomb May 20, 2017
    jhalayashraj , May 20, 2017 :
    Yeah as people wanted better battery so i tried to improve it.
  2. ElRobertson
    Gingerbread May 20, 2017
    Tokkan, se7enlyn and ziepicwaffle like this.
  3. SpeedbirdMotorcycles
  4. jhalayashraj
    Honeycomb May 21, 2017
    jhalayashraj , May 21, 2017 :
    No. Clean flash is recommended as so many changes on kernel side.
    SpeedbirdMotorcycles likes this.
  5. adi_daga
    Gingerbread May 21, 2017
    adi_daga , May 21, 2017 :
    Feature request...
    Can u add option to show Ampere instead of volts on lockscreen while charging..
    Nd btw rom has really nice standby..no need to flash intense kernel.
  6. ziepicwaffle
    Ice Cream Sandwich May 21, 2017
    ziepicwaffle , May 21, 2017 :
    There's an app on the playstore called OPO charging current. It works well for me and tells you the charging current real time.
    adi_daga, silverview and se7enlyn like this.
  7. adi_daga
    Gingerbread May 22, 2017
    adi_daga , May 22, 2017 :
    Anyone having trouble logging FB nd messenger beta apps on latest version of ROM...or is it just me..Other internet connectivity is fine..no data nd WiFi blocking ..infact unrestricted access ..no changes done in privacy guard..apps not hibernated in Greenify...still both apps shows no "active connection"
  8. sathish D C
    Gingerbread May 23, 2017
    sathish D C , May 23, 2017 :
    Device getting reboot 3 or 4 times a day after flashing 16.0 anyone facing same issue ?
  9. se7enlyn
    Ice Cream Sandwich May 23, 2017
    se7enlyn , May 23, 2017 :
    Nope, zero reboots
    silverview and ziepicwaffle like this.
  10. F_Mithun_Wijethunga_orur
    Cupcake May 23, 2017
  11. Tarfex
    Ice Cream Sandwich May 25, 2017
    Tarfex , May 25, 2017 :
    ya I am getting random reboots too.
  12. silverview
    Gingerbread May 25, 2017
    silverview , May 25, 2017 :
    No reboots for me. Clean flashed 16.0 coming from another rom.
    In fact I'm having no issues. LegendRom has noticeably better battery life than any other Nougat rom I have used. Lots of customization options and no performance problems. Many thanks to the devs for sharing your work.
    ziepicwaffle and se7enlyn like this.
  13. sathish D C
    Gingerbread May 26, 2017
    sathish D C , May 26, 2017 :
    Reboots when changing cpu governer to smartmax eps.
  14. jhalayashraj
    Honeycomb May 30, 2017
    jhalayashraj , May 30, 2017 :
    Yes some users reported smartmax eps giving random reboots. Will look into it till thn you can use interactive if you are getting random reboots in that too thn it's from Lineage side and reported on jira.
  15. jhalayashraj
    Yes 16.0 took so much time and testing for making kernel Legendary.
  16. sathish D C
    Gingerbread May 30, 2017
    sathish D C , May 30, 2017 :
    Thanks @jhalayashraj , 16.0 with interactive cpu setting works great without any issues and better battery life. smartmax eps gives more battery life but facing reboot issue.
  17. rsennat
    Donut Jun 13, 2017
  18. ElRobertson
    Gingerbread Jun 13, 2017
    ElRobertson , Jun 13, 2017 :
    @jhalayashraj
    Hi,
    I'm just here to say thank you for your ROM!
    I've lost my OPO while I was drunk so I can't experience your work anymore. :(
    And no, I won't be OnePlus Devices anymore (I was a bit disappointed from OP, as we, the early customers from the first days who helped this factory to get a good name, where simply ignored and were not good treated as the new devices came up.)
    So - thank you! :)
    Greetings from Bavaria! B.
    PS: You don't develop for the BQ Aquaris X5 Plus too, do you? :)
    jhalayashraj and ziepicwaffle like this.
  19. ziepicwaffle
    Ice Cream Sandwich Jun 14, 2017
    ziepicwaffle , Jun 14, 2017 :
    If you download kernel adiutor, you can change the cpu settings
  20. Taalen
    Cupcake Jun 18, 2017
    Taalen , Jun 18, 2017 :
    Been using 16.0 for around a month now - thank you! Some issues I've come come across though:
    -pretty frequent random reboots (but at least much faster than they were with Cyanogen)
    -pictures messed up if using flash in stock camera app, there will be a visible line in the picture, dividing it into light and dark areas.
    -frequently drops from wifi for half a minute or so. So far I've only confirmed it happening with my home wifi, so might have something to do with the box in question
    -might be just my memory playing tricks on me, but max screen brightness feels dimmer than it used to be with Cyanogen. In general I use pretty dim settings, but sometimes I struggle to get brightness high enough
    -battery consumption is pretty bad compared to Cyanogen, unfortunately
    Regardless of some teething issues, pretty fine job. Keep up the good work.
