48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. jhalayashraj
    Honeycomb Oct 15, 2016
    jhalayashraj , Oct 15, 2016 :
    We are gonna work on OTA thing soon.
    TimoV likes this.
  2. jhalayashraj
    Snapchat is working fine here.
    akshansh2000 likes this.
  3. therishabh
    Cupcake Oct 15, 2016
  4. ziepicwaffle
    Ice Cream Sandwich Oct 15, 2016
    ziepicwaffle , Oct 15, 2016 :
    Snapchat recently implemented a root checker so if you log out and try log back in, it will not work. Have to either use suhide or full unroot, log in to Snapchat, then root again
  5. TimoV
    TimoV , Oct 15, 2016 :
    Thanks man :) great rom btw on every other aspect, getting great battery life here :D
    jhalayashraj likes this.
  6. pikota
    Marshmallow Moderator Oct 15, 2016
    pikota , Oct 15, 2016 :
    F2FS whit open gapps don't work.
    What gapps flash?
  7. jhalayashraj
    Still u can't change the battery icon but yes u can enable battery percentage in the icon by going to status bar icons.
  8. jhalayashraj
    As far as i know suhide has flashable zip file right ?
    ziepicwaffle likes this.
  9. sg01fc
    Gingerbread Oct 15, 2016
    sg01fc , Oct 15, 2016 :
    Interesting, I have the option for that but it didn't do anything. Also, I clean flashed this and at the end of the day it would only charge for about a minute then would stop charging. Had to go back to SlimSaber overnight. May mess with this ROM again later as otherwise it was a smooth build.
  10. ziepicwaffle
  11. jstepa
    KitKat Oct 15, 2016
  12. jhalayashraj
    That's weird.
  13. jhalayashraj
    jstepa likes this.
  14. jstepa
    KitKat Oct 15, 2016
  15. ziepicwaffle
    I tried .54 version of suhide but I screwed up somewhere with my root version so that's my fault. Ended up unrooting then rooting after login XD
    jstepa likes this.
  16. therishabh
    Cupcake Oct 16, 2016
    therishabh , Oct 16, 2016 :
    the ringtones on this ROM sound crisp and clear which is rare on nougat roms at this stage(tried 4 nougat roms)
  17. Anonymous_unknown
    Froyo Oct 16, 2016
    Anonymous_unknown , Oct 16, 2016 :
    What's this 'miscellaneous' thing in all N roms that is draining most of the battery and i am not getting more than 3.5 hours sot on this rom
    If anyone can help me in getting more SOT
    Like what gapps and kernel u guys are using to get more than 5 hours SOT
  18. se7enlyn
    Ice Cream Sandwich Oct 16, 2016
    se7enlyn , Oct 16, 2016 :
    Try using private kernel. For me, r1 works better than r3
  19. jhalayashraj
    Honeycomb Oct 16, 2016
    jhalayashraj , Oct 16, 2016 :
    Miscellaneous is not draining battery still if u want to remove miscellaneous from battery stats change ro.build.type=user in build.prop.But still if u are not getting better battery life thn try private kernel as per users are having nice battery life with that kernel.
    se7enlyn likes this.
  20. Jazz365
