48
ROM [LineageOS-14.1][7.1.1][OMS7] LegendROM
  1. Archies
    Ice Cream Sandwich Oct 16, 2016
  2. jhalayashraj
    Honeycomb Oct 16, 2016
  3. Dojojo122
    Donut Oct 16, 2016
  4. jhalayashraj
    se7enlyn and ziepicwaffle like this.
  5. Jazz365
    Jazz365 , Oct 16, 2016 :
    Just tried it , unfortunately doesn't work for me. Long pressing the menu hardware button doesn't open recents.
  6. Dojojo122
    Donut Oct 16, 2016
    Dojojo122 , Oct 16, 2016 :
    Thanks. One more question how to change battery icon to percentage? And is there no theme changer.
  7. jhalayashraj
    jhalayashraj , Oct 16, 2016 :
    U can't change battery icon to only percentage its cm bug and u can install substratum but as this is cm base ROM it may not work nicely. Hope cm port theme engine to cm14 soon.
    se7enlyn likes this.
  8. jhalayashraj
    Oh my bad i misunderstood your question.
  9. Dojojo122
    Donut Oct 16, 2016
    Is it possible to change lockscreen wallpaper?
  10. butaixyz8016
    butaixyz8016 , Oct 16, 2016 :
    App permission doesn't show properly in app, need to go to settings for granting permission
  11. se7enlyn
    se7enlyn , Oct 16, 2016 :
    Yes, use Google launcher, change the lockscreen wallpaper and then go back to your preferred launcher
  12. se7enlyn
    Reinstall the ROM and this time, use slim Gapps
  13. se7enlyn
    Sir, build 2.1, the battery performance profile setting shows some weird symbols.
    System profiles still not working.
  14. jhalayashraj
    Ya it might because i merged instantly that commit just after cm added.
    Will be solved from next build.
    ziepicwaffle and se7enlyn like this.
  15. se7enlyn
    It's OK with me, take your time, minor issues, just my feedback.
    IMHO, this is still the best nougat so far.
    jhalayashraj likes this.
  16. jhalayashraj
    Thanks for the support.
  17. jhalayashraj
    Yes if u r using opengapps thn use the latest opengapps and banks gapps , slim gapps are tested and working perfect.
  18. Dojojo122
    Donut Oct 16, 2016
    I tried the method told by you. Downloaded Google Now Launcher but unable to set it as default.
  19. jhalayashraj
    For google now launcher u must install google app first and thn download the google now launcher and for changing lockscreen image u can also use pixel launcher and nova.
    Pixel is simply giving this option.
  20. sg01fc
    Gingerbread Oct 16, 2016
    sg01fc , Oct 16, 2016 :
    OK, so I think that the issue was that I had Private r3 kernel installed. When I clean flashed with the stock kernel the charging was fine (although it didn't get to 100% after 9 hours charging, it was at 99%). So far it's a really smooth ROM with great battery life. I'm not on the phone a lot and since I took it off the charger this morning at 9:00 it is only down to 81% (~6 1/2 hours). This is better than I was seeing on SlimSaber. I did do a lot of tweaks in Privacy Guard, notifications and bootup apps.
