LineageOs NIGHTLY updates Installation Problem
  1. tOot.toOt Froyo Aug 5, 2017
    tOot.toOt, Aug 5, 2017 :
    My device is rooted and currently running on Lineage Os 14.1 20170713 NIGHTLY Everything is great but m unable to install the latest 3 NIGHTLY updates. In TWRP the installation fails with message Error 7 , assert Failed : op3.verify modem .
    I searched for the issue in internet, And tried to install the UPDATES by Editing (updater_script) and removing assert phrase . And Installed the ZIP successfully but the Fingerprint scanner+home Key stopped working . Then i switched back to LINEAGE OS 14.1 20170713 NIGHTLY and everything works normal . So anyone plz suggest me the way to Flash the latest Update without getting error 7.
    Paul de Monchy likes this.
  2. G_Sir_Nando_zPmF Eclair Aug 5, 2017
  3. G_Sir_Nando_zPmF Eclair Aug 5, 2017
    G_Sir_Nando_zPmF, Aug 5, 2017 :
    Link didnt seem to work, but just search "lineage os bypass error 7" and it should be the video by MS tech India Official
    tOot.toOt likes this.
  4. SiniciXp Froyo Aug 8, 2017
    SiniciXp, Aug 8, 2017 :
    Which steps are you taking?
    there are 3 options when I search for lineageos bypasserror 7
  5. Paul de Monchy Cupcake Aug 15, 2017
    Paul de Monchy, Aug 15, 2017 :
    Hi,
    I have exactly the same issue.
    Do you guys know how to contact the lineageos team to report the bug?
    Regards,
    Paul.
  6. Cosmos_NT Jelly Bean Aug 15, 2017
  7. _DEDSEC_ Jelly Bean Aug 15, 2017
  8. Mt.Everest Froyo Aug 15, 2017
  9. Paul de Monchy Cupcake Aug 15, 2017
    Hi,
    @PraCas_KhatiwAda, I've just fixed this issue by upgrading my modem, following advices on this page: https://www.reddit.com/r/LineageOS/comments/6on5lu/op3_20170721_update_instructions_for_noobies/.
    However, the modem version given wasn't for 3t devices, so I took the "firmware-update/NON-HLOS.bin" file from http://oxygenos.oneplus.net.s3.amaz...8_OTA_029_all_1708021855_80477ecd615347a7.zip and pasted it in the "modem only" archive found on https://forum.xda-developers.com/oneplus-3/how-to/radio-modem-collection-flashable-zips-t3468628.
    It works like a charm ;-)
    Regards,
    Paul.
  10. SoniaB Nougat Senior Moderator Aug 15, 2017
  11. Millig Gingerbread Aug 15, 2017
    Millig, Aug 15, 2017 :
    You have to flash the modem+firmware that suits to the ROM.
    If it's recent ROM, it could be the last stable firmware or the last Open Beta firmware. Just check that you flash the firmware for the OP3 and not for the 3T (if you have a 3)
  12. tOot.toOt Froyo Aug 16, 2017
    tOot.toOt, Aug 16, 2017 :
    i haven't tried it yet . but i'll, thanks :)
  13. tOot.toOt Froyo Aug 16, 2017
    Ya it is, but SOT n aru power saving related tweak ko lagi lineage rom is best, try it once.
  14. Mt.Everest Froyo Aug 17, 2017
    Mt.Everest, Aug 17, 2017 :
    Wifi ko setting ma gayera wifi never on while sleep ma change garya, I'm getting 6hours SOT. And few setting
  15. sumonuap Gingerbread Aug 19, 2017
