2
Liquid or debris issue in USB port via OnePlus 7T
  1. K1570136913315
    Cupcake Sep 20, 2020
    K1570136913315 , via OnePlus 7T , Sep 20, 2020 :
    While connecting USB for chargng below error is popping up
    "LIQUID OR DEBRIS IN USB PORT" for OnePlus 7t.
    Have tried several times cleaning the USB port and cable still facing same issue phone is not getting charged.
    Is anyone is facing similar issue?
  2. Rajendra.Bhat
    Jelly Bean Sep 20, 2020
  3. aliameer01
    Cupcake Sep 24, 2020
  4. naheedmir
    Gingerbread Sep 24, 2020
    naheedmir , Sep 24, 2020 :
    Hi there,
    Such an aissue is rare. If there isn't any debris or liquid, port should work. Keep trying after a while, this problem will not stay long. If remains unsolved, please go for the Customer Support of OnePlus.
  5. Tokolozi
    Most Original Avatar Sep 24, 2020
    Tokolozi , Sep 24, 2020 :
    Hey, try to have your phone dried out for a while, usually you get this error when there's something conductive between the contracts.
    You could also try cleaning it with some isopropyl alcohol when the device is off.
  6. IanBartolome
    Cupcake Oct 11, 2020
  7. milos vasic
    Cupcake Jan 9, 2021
    milos vasic , Jan 9, 2021 :
    Guys, I solved the issue of not charging due to debris and liquids with OP8 Pro as well as many other issues I faced. I simply changed it with other brand. OP is not the same phone it used to be. I've been using OP since the beginning and unfortunately OP became unreliable maker so I decided to switch to another brand.
    Srirupdutta likes this.
  8. #8
  9. Hyperspacey
    Gingerbread Feb 17, 2021
    KluGe and Tobikage like this.
  10. #10
  11. Tokolozi
    Most Original Avatar Feb 17, 2021
    Tokolozi , Feb 17, 2021 :
    Make sure to clean out the USB port, and see if there isn't any lint or moisture in the connector.
  12. #12
  13. Hyperspacey
    Gingerbread Feb 18, 2021
