2
Location/gps not working
  1. Ashwinmhatwalne
    Eclair Sep 15, 2018
    Ashwinmhatwalne , Sep 15, 2018 :
    After updating to 5.0.5, my op3t location detection is not working even on high accuracy. Any solutions?
  2. CarvedArt
    Froyo Sep 16, 2018
    CarvedArt , Sep 16, 2018 :
    Not my files, but works...
    Try the GPS.config from here: https://dl.xda-developers.com/4/5/3....zip?key=i0a_-tnC3ID2j1J63gElkw&ts=1537063453
    Then after you've installed and rebooted your device, make sure your location settings is setup on mode Device only go outdoors, with a line of sight to the sky, download GPS Locker app from the Google Play Store, open the app and wait for the first time fix/locklock
    If you're rooted use the Magisk Module
    Global Optimized GPS File Replacer
