17
Location Icon Always On
  1. SJB_SANKET
    Cupcake Nov 11, 2020
  2. krube37
    Eclair Nov 11, 2020
  3. hanz_rao
    Cupcake Nov 12, 2020
  4. Ejas1786
    Cupcake Nov 13, 2020
  5. Styler_sd
    Froyo Nov 14, 2020
  6. OmarRolon
    Gingerbread Nov 15, 2020
    OmarRolon , Nov 15, 2020 :
    Consulta los permisos que tienen las aplicaciones con regularidad.Check the permissions that the applications have, they are usually Google services, it may also be that you are in the beta
    MRTLima likes this.
  7. MRTLima
    Gingerbread Nov 16, 2020
  8. MRTLima
    MRTLima , via OnePlus 7T , Nov 16, 2020 :
    I agree with you. Usually google services tend to use location...
  9. Dhaval@21
    Cupcake Nov 17, 2020
  10. MRTLima likes this.
  11. Janefernandes
    Cupcake Nov 18, 2020
    MRTLima likes this.
  12. OmarRolon
    Gingerbread Nov 19, 2020
    MRTLima likes this.
  13. MRTLima
  14. prodigysharma
    Cupcake Nov 22, 2020
  15. OmarRolon
    Gingerbread Nov 22, 2020
  16. MRTLima
    MRTLima , via OnePlus 7T , Nov 22, 2020 :
    When my 7T phone arrived. Three weeks after I tried to delete files folder. And my phone almost died. I rebooted and reinstalled...
    I think that some folders you just can't delete.
    I hope you can do without problems.
  17. JiNnY.17
    Cupcake Nov 24, 2020 at 3:47 PM
    JiNnY.17 , via OnePlus 7T Glacier Blue , Nov 24, 2020 at 3:47 PM :
    There are some apps that use location.
    Go to permission and disable all apps that use location.
    Even camera uses the location.
    Also there are some system apps that use the location.
    Make sure u turn them off.
    You might face some issues that are directly or indirectly using the location app.
    May this be of any help.
