38
Location Icon Always On
  1. Sashank_10
    Gingerbread Dec 13, 2020
    MRTLima likes this.
  2. Karx100
    Gingerbread Dec 14, 2020
    Karx100 , via OnePlus 7T , Dec 14, 2020 :
    I have not faced this issue on my 7T. But as you are facing this issue, you can go into settings and turn off location access permission of individual apps as that might help. Also try factory reset on your device.
  3. OmarRolon
    Honeycomb Dec 14, 2020
  4. amit_baral_31
    Eclair Dec 14, 2020
  5. luvjakhar
    Cupcake Dec 14, 2020
  6. luvjakhar
    MRTLima likes this.
  7. MRTLima
    Lollipop Dec 14, 2020
  8. ango123456
    ango123456 , via OnePlus 7T Glacier Blue , Dec 14, 2020 :
    Is there a way to activate the 4G network without having to activate the data
    Because there are some companies supporting the property of calls over the 4G network but in order to use this property it is necessary to activate the phone data is there a solution
    MRTLima likes this.
  9. yamandabas
    Eclair Dec 14, 2020
  10. OmarRolon
    Honeycomb Dec 15, 2020
  11. Gopi Ram 26
    Cupcake Dec 15, 2020
  12. Naveen_chintala
  13. amit_baral_31
    Eclair Dec 16, 2020
  14. vpsapravin
    Donut Dec 16, 2020
    vpsapravin , via OnePlus 7T , Dec 16, 2020 :
    Even though if u disable the local, some app may use that function. And you would have given permission to it. If you deny all permission then that icon will not be displayed.
    MRTLima likes this.
  15. MRTLima
    Lollipop Dec 16, 2020
    MRTLima , via OnePlus 7T , Dec 16, 2020 :
    That seems to be a good idea too. Nice work.
  16. maddyrock , via OnePlus 7T Glacier Blue , Dec 16, 2020 :
    It's simple you give permission for apps to use location when needed just select only when app is used instead of always on for that app...it runs in the background when you receive a notification...so it's always on most of the times
  17. OmarRolon
    Honeycomb Dec 17, 2020
  18. sufi09
