35
Location Icon Always On
  1. notoriousvinay
    Cupcake Sep 26, 2020
    #61
  2. tssshanmukhas
    tssshanmukhas , via OnePlus 7T , Sep 26, 2020 :
    I have seen this recently after the new security patch update I guess. After using the location services in maps when I turned off the symbol is not vanishing..please check
    Thanks
    #62
    mohammed2501 likes this.
  3. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 28, 2020
    Dresa91 , Sep 28, 2020 :
    Hi,
    there are already bug reports submitted:
    https://forums.oneplus.com/threads/location-symbol-is-displayed-even-if-location-is-off.1309000/
    and
    https://forums.oneplus.com/threads/location-symbol-constantly-displayed.1307154/
    can you please try this workaround:
    https://forums.oneplus.com/threads/...or-the-location-symbol-in-status-bar.1308291/
    #63
  4. tssshanmukhas
    Cupcake Sep 28, 2020
  5. Dresa91
    okay.
    then please wait for an update and be patient.
    this is a user forum...
    #65
  6. Dresa91
    okay.
    #66
  7. tssshanmukhas
    #67
    Dresa91 likes this.
  8. Vaibhav0398
    Froyo Sep 28, 2020
    Vaibhav0398 , via OnePlus 7T , Sep 28, 2020 :
    Yess same thing happening with me also😑
    #68
  9. Shameerz_oneplus , via OnePlus 7T Pro , Sep 28, 2020 :
    The issue got resolved to me , search for OnePlus launcher app in playstore hope it ask for either uninstall or update .either uninstall and reinstall it or just do the update part it fixed my issue hope this helps ...[e]270c[/e]️
    #69
  10. Gautm23
    #70
  11. VB1
    Gingerbread Sep 28, 2020
    VB1 , via OnePlus 7T , Sep 28, 2020 :
    Open Google maps. Give location permission. Just let the GPS pin your current location. Exit Google maps & turn off the location permission. It will probably resolve the issue.
    #71
  12. V1597079166579
    Cupcake Sep 29, 2020
    #72
  13. #73
  14. Nitesh nayak
    Cupcake Oct 1, 2020
    #74
  15. Dr.TanmayPatel
    Donut Oct 1, 2020
    Dr.TanmayPatel , Oct 1, 2020 :
    hey OnePlus team , my location service is showing constantly on. though I don't have any apps that needs constant location data. please fix this bug. after every restart location data is constantly on.
    #75
    Mohit Dwarkani likes this.
  16. #76
    Dr.TanmayPatel likes this.
  17. R1590656488624
    Cupcake Oct 2, 2020
    R1590656488624 , Oct 2, 2020 :
    Same issue here.
    Notification icon for location is on even if I disable location.
    Looks like it's a notification area bug, not actually location being used.
    #77
  18. Ambablu
    Donut Oct 2, 2020
    #78
  19. Ambablu
    Donut Oct 2, 2020
  20. Ambablu
    Donut Oct 2, 2020
    #80
