28
Location Icon Always On
  1. harshitrathore
    Cupcake Oct 2, 2020
    harshitrathore , via OnePlus 7T , Oct 2, 2020 :
    I do not even have gpay installed in my phone even then its happening. It gets resolved sometimes but keeps on happening back repeatedly. I think there are too many bugs in the OS right now.
    #81
  2. harkanwar singh
    Cupcake Oct 2, 2020
  3. #83
  4. DrKTM1+7t
    Froyo Oct 4, 2020
    DrKTM1+7t , via OnePlus 7T , Oct 4, 2020 :
    mine too got permenant fix on restarting the phone
    #84
  5. Darshankawade
    Donut Oct 4, 2020
    Darshankawade , via OnePlus 7T , Oct 4, 2020 :
    I tried revoking location permissions from all the apps but the location sign won't go off.
    Sometimes rebooting device helps, but it comes back again.
    Anyone else facing this issue?
    #85
  6. Bobbie63
    Marshmallow Oct 4, 2020
    Bobbie63 , Oct 4, 2020 :
    I've seen a lit of people having this issue, have you also turned of location of scout (if you have it) and the launcher?
    #86
  7. Darshankawade
    Donut Oct 4, 2020
    Scout is disabled and none of the other apps are using location all the time.
    #87
  8. Bobbie63
    Have you turned them all off in permissions? If so try a reboot and see what happens.
    Should it still be there better submit a bug
    #88
  9. Darshankawade
    Donut Oct 4, 2020
    #89
  10. Abhinav.singh93
    Eclair Oct 5, 2020
    Abhinav.singh93 , Oct 5, 2020 :
    I also had this exact same problem and I solved it by turning off location access permissions to One plus launcher. Maybe you should try this too?
    #90
  11. PK1233
    Eclair Oct 5, 2020
    #91
  12. Nandal420
    Cupcake Oct 5, 2020
    #92
  13. Bhaveee
    Honeycomb Oct 6, 2020
    Bhaveee , via OnePlus 7T , Oct 6, 2020 :
    Go to settings> location> app permission and check which apps have location access always and turn it off or turn it to only while using the app. You can simply revoke the permission and when u open the app mext time select"only while using the app" when ask for permission
    #93
  14. Sudheer439
    Cupcake Oct 6, 2020
    #94
  15. Darshankawade
    Donut Oct 6, 2020
    #95
  16. J1579602732209
    Cupcake Oct 6, 2020
    #96
  17. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 6, 2020
  18. Swejuggalo
  19. Y1539619610939
    Eclair Oct 6, 2020
    Y1539619610939 , via OnePlus 7T , Oct 6, 2020 :
    After restarting it goes but if you turn location on and off again.. that issue will come again
    #99
  20. Thirumalesh.S
    Cupcake Oct 7, 2020
    R1591996918565 likes this.
