location
  1. JUANJASHIDA
    Cupcake Aug 30, 2017
  2. G_Joe_Smart_Ltmx
    Honeycomb Aug 30, 2017
    G_Joe_Smart_Ltmx , Aug 30, 2017 :
    Honestly people complain about problems with the GPS on the OnePlus 5 every day. Are you getting any kind of error message in Maps indicating that it isn't connecting to a GPS network?
  3. kebaros
    Froyo Aug 30, 2017
  4. G_Prateek_Mishra_dFiG
    G_Prateek_Mishra_dFiG , Aug 30, 2017 :
    Uninstall the Maps update to factory data through Settings--> Apps.
    Restart your phone.
    Then update the Maps through playstore.
    It solved issue for me. Hope it helps.
  5. Abir lohiya
    Donut Aug 30, 2017
  6. F_Gowrav_Gs_oUYd
    Cupcake Sep 22, 2017
    F_Gowrav_Gs_oUYd , Sep 22, 2017 :
    I had the same issue with one plus 5, I turned on the location history for the device one plus in location settings, and it started working..let me know if this solves ur problem
  7. G_CH_SAIVARUN_REDDY_Hfwv
    Cupcake Oct 1, 2017
  8. Jackson george
    Froyo Oct 1, 2017
