Lock box
  1. Dheeraj.N.G
    Cupcake Jan 21, 2020
    Dheeraj.N.G , Jan 21, 2020 :
    Earlier we had an option to unlock lockbox with fingerprint but after the recent update this feature has been removed . I forgot the pin
    Is there any option to reset the pin
  2. Kytharsis
    Marshmallow Jan 21, 2020
    Kytharsis , Jan 21, 2020 :
    Your PIN is your phone's lock code. If you forgot that, you'd need to reset your entire phone.
  3. Dheeraj.N.G
    My pin is only four digit and lock box is asking for 6 digit code
  4. Kytharsis
    Screenshots help.
  5. Dheeraj.N.G
    phone unlocks with only 4 digit code
    and lock box expects 6 digit code
    i hope I'm clear enough
  6. Kytharsis
  7. Dheeraj.N.G
    I haven't formatted my device since long time
  8. Kytharsis
    I suggest doing it, either to fix any problems like your Lockbox code problem or to solve any underlying issues. Your Lockbox items will be gone however.
  9. Dheeraj.N.G
    I can't afford loosing data
    Anyways thank you sir for your response .I hope this problem will b solved
  10. Kytharsis
    I gave you the solution. If you forget you code(s) the only way is to format it and start over.
  11. Dheeraj.N.G
    Actually in the beginning the code which i used was only four digits and i remember that
    After recent update it's requesting for six digit code don't know why
  12. Kytharsis
    Again. Gave you the solution.
  13. RogerOriginals
    Ice Cream Sandwich Jan 22, 2020
    RogerOriginals , via OnePlus 6T Mirror Black , Jan 22, 2020 :
    Lockbox uses a separate 6 digit pin that is to be set when settings up lockbox for the first time. If you forget the pin the only way to reset it is use FP scanner to log in and reset the PIN. I do have fingerprint option in my Lockbox, how come yours got removed? Are you on Open Beta?
    Kytharsis likes this.
  14. cutterman
    Cupcake Jan 28, 2020
