Lock screen animation
  1. mbcool Gingerbread Jan 3, 2018
    mbcool, Jan 3, 2018 :
    After updating my 3T to OOS 5.0.1 i found that the animation going from lock screen to home screen has changed.
    only the navigation baar is showing the animation and not the icons
  2. NeVeR_SeTTLe Lollipop Jan 3, 2018
    NeVeR_SeTTLe, Jan 3, 2018 :
    Not sure what you mean. Please elaborate and if you can, post some screenshots.
  3. mbcool Gingerbread Jan 3, 2018
    That pull up animation where the navigation bar and icons seems to come from bottom when unlocking the phone.
    after the update the same is only visible in navigation bar and icons come up with no such animation
  4. NeVeR_SeTTLe Lollipop Jan 3, 2018
    Hmmm...I still don't understand what you mean. I unlock my phone with fingerprint, so I don't see any animations.
  5. mbcool Gingerbread Jan 3, 2018
    try using pattern
  6. NeVeR_SeTTLe Lollipop Jan 3, 2018
  7. mbcool Gingerbread Jan 3, 2018
    Did you see the difference?
  8. NeVeR_SeTTLe Lollipop Jan 3, 2018
    For me the notification bar and icons come with animation.
  9. mbcool Gingerbread Jan 3, 2018
    but in my case it's only the navigation bar that comes with that animation all the home screen icons do not animate
  10. NeVeR_SeTTLe Lollipop Jan 3, 2018
    What version of Oxygen OS are you on?
  11. mbcool Gingerbread Jan 3, 2018
    5.0.1 i saw this issue first time on 5.0 i thought it's meer bug and might be fixed in next update but the issue still persist
  12. NeVeR_SeTTLe Lollipop Jan 3, 2018
    Hmmm..I am not having this issue, I am on 5.0. Did you try wiping cache from recovery?
  13. mbcool Gingerbread Jan 3, 2018
    several times
  14. NeVeR_SeTTLe Lollipop Jan 3, 2018
    I heard that Oxygen OS 5.0.1 had some bugs, so they pulled the update and they started releasing it again today with improved corrections. Did you install the update today or is it the old 5.0.1 update?
  15. mbcool Gingerbread Jan 3, 2018
    old update
  16. NeVeR_SeTTLe Lollipop Jan 3, 2018
    Wait for the new update, see if it gets fixed. I would also recommend you after the update to do a factory reset.
