lock screen issue
  1. Sivabala D
    Cupcake Jul 8, 2018
  2. the_o2
    OnePlus 9 Series Expert Community Expert Jul 8, 2018
    the_o2 , Jul 8, 2018 :
    Your attachment is broken try to upload it properly..
    And lock screen pattern is used for unlocking the screen not for locking :rolleyes:
    Artemus. likes this.
  3. stark2991_PL
    KitKat Jul 10, 2018
  4. Sivabala D
    Cupcake Jul 10, 2018
    Sivabala D , Jul 10, 2018 :
    lock screen issue lock icon in lock screen not locks (it shows unlock symbol) may I know the reason for this issue
  5. AdithyaBitling
    AdithyaBitling , Jul 10, 2018 :
    Maybe you have enabled Motion Unlock. Once you unlock the device,if it is motion,then it won't locks the device until you keep the device aside for a while.
  6. Sivabala D
    A1528720633997 likes this.
  7. AdithyaBitling
    You can find On-Body detection unlock in below
    Open your device's Settings app .
    Tap Security & Location then go to Smart Lock.
    Enter your PIN, pattern, or password.
    Turn off On-body detection and remove all trusted devices, trusted places, trusted faces, and Voice Match voices.
  8. Liehjan
    Marshmallow Jul 10, 2018
