Lock screen wallpaper not changing?
  1. mirko77
    Froyo Aug 15, 2014
    mirko77 , Aug 15, 2014 :
    I might be missing something, but when I go to Settings>Themes>Lock Screen wallpaper and I select an image, it does not seem to work.
    I am always getting my home screen background on my lock screen despite I select a different image.
    Is there any checkbox somewhere else to tick? Thanks
    BTW: I have custom lock screen disabled, is that the reason?
    Deactivated User likes this.
  2. dragon2777
    Jelly Bean Aug 18, 2014
    dragon2777 , Aug 18, 2014 :
    Seemed to work for mesothelioma the custom lock screen just make sure that you hit set wallpaper at the top left after you choose an image and not just back.
  3. Sharifashraf
    Honeycomb Aug 18, 2014
    safadi likes this.
  4. macktheknife
    Froyo Aug 18, 2014
    macktheknife , Aug 18, 2014 :
    I have the same problem. It won´t change...have change under themes, but it just display my wallpaper
  5. marikathomas
    Gingerbread Aug 18, 2014
    marikathomas , Aug 18, 2014 :
    mine changed but half of it is the light blue screen, at the top I see a part of my new picture
  6. macktheknife
    Froyo Aug 18, 2014
    Yes but that is the CM11S lockscreen...I don´t want that, I want it with widgets and shortcuts...and that wallpaper won´t change
    dagy304, Hairyharris1980 and WuTang like this.
  7. mosesv26
    mosesv26 , Aug 18, 2014 :
    I don't know I tried the same and my picture came out weird so I switched to the regular lock screen seems to be working.
  8. dragon2777
    As far as I understand you can't change the blue past is part of the theme
  9. gqkevyn
    Froyo Aug 18, 2014
    gqkevyn , Aug 18, 2014 :
    Yeah I've been experiencing this as well. Just came from S4 and Note 2 before that, which allowed different wallpapers for both lockscreen and regular wallpaper.
    This is with custom lock screen disabled as I want the widgets and fast access to camera. Changed it it settings-> themes-> lock screen wallpaper but nothing happens. When I enable custom lock screen the wallpaper I picked does show up on the top part.
  10. WuTang
    WuTang , Aug 18, 2014 :
    Have the same bug..
  11. DarchAmonNagar
    Froyo Aug 18, 2014
    DarchAmonNagar , Aug 18, 2014 :
    I'm also having this bug.
  12. Hairyharris1980
    Hairyharris1980 , Aug 18, 2014 :
    Yeah mine is the same. I like the lock screen with widgets and a nice clear wallpaper. Would be great to have a different lock screen picture, instead of the same pic I use for my home screen.
  13. vitamindon
    Gingerbread Aug 19, 2014
    vitamindon , Aug 19, 2014 :
    Just read the forums, it's a know bug that came in with the 300 update, it and a few other things will be patched in a couple of days.
  14. safadi
  15. fungwon
    Froyo Aug 19, 2014
    fungwon , Aug 19, 2014 :
    I have the same issue, Lock screen wallpaper won't change, it just show my home screen wallpaper.
    Hope it will get fix soon.
  16. oldmike
    Froyo Aug 20, 2014
    oldmike , Aug 20, 2014 :
    Supossedly the fix will be in the next update that also fixes the battery drain.
  17. dagy304
    Gingerbread Aug 20, 2014
  18. Raiyan416
    Cupcake Aug 21, 2014
    Raiyan416 , Aug 21, 2014 :
    I have same problem after update to 4.4.4
  19. mirko77
    Froyo Aug 21, 2014
    mirko77 , Aug 21, 2014 :
    They say it should be fixed on the next OTA
  20. Raygen
    Donut Aug 22, 2014
