lockscreen
  1. killer.sid19
    Cupcake Sep 23, 2017
    killer.sid19 , Sep 23, 2017 :
    how I will change my oneplus 5 lock screen wallpaper? I am not getting option for changing lockscreen wallpaper.
  2. Nezumi_
    KitKat Sep 23, 2017
    Nezumi_ , Sep 23, 2017 :
    change your wallpaper from stock launcher and swipe left on the wallpaper chooser screen.
    ptlyadvendra and lostLambda like this.
  3. killer.sid19
  4. Torica
  5. Nezumi_
    KitKat Sep 23, 2017
    you can choose lockscreen wallpaper from there, just try it out yourself.
    also i believe if you're using a custom launcher you'll be asked whether to change the lockscreen wallpaper or not if you're trying to change your wallpaper.
  6. Dushyant192
    Eclair Sep 23, 2017
    Dushyant192 , Sep 23, 2017 :
    Go to gallery
    Choose your open. Your wallpaper
    Then on the right side three dots click on.. That
    Then select set as wallpaper
    Then click on apply
    Then select lockscreen....
    Done.
  7. killer.sid19
  8. Dushyant192
    Eclair Sep 23, 2017
    Go to gallery
    Then click on apply
    Done.
    ptlyadvendra likes this.
  9. Nezumi_
    KitKat Sep 23, 2017
    swipe left, see attached image.
    this is the wallpaper that applies to your lockscreen. Screenshot_20170923-102212.png
    ptlyadvendra and SMIT222 like this.
  10. Jackson george
    Froyo Sep 23, 2017
  11. SMIT222
    Gingerbread Sep 23, 2017
    SMIT222 , Sep 23, 2017 :
    This is the solution of your problem
