Long press volume control via OnePlus Nord
  1. ankit908raj
    Donut Nov 29, 2020
    ankit908raj , via OnePlus Nord , Nov 29, 2020 :
    Pressing the volume control for long doesn't increase/decrease the sound in one go. Instead I have to continuously tap the up/down key to increase/decrease the sound.
    Is it normal for the OnePlus Nord or my device is having some issues?
    Edit: It got fixed after a restart.
    H1600181198807 likes this.
  2. ashishlp007
    Ice Cream Sandwich Nov 29, 2020
    ashishlp007 , via OnePlus Nord , Nov 29, 2020 :
    Ideally its should work. On long press, volume should increase or decrease.
    Looks like an issue. Log a bug.
    But after as you mentioned that its working. So, I hope it doesn't repeat.
  3. Abhishek@3672
    Cupcake Jan 5, 2021
    Abhishek@3672 , Jan 5, 2021 :
    I am facing the same issue with OnePlus 7t.. in which holding on up volume button doesn't increase the volume , while down volume button is working. rebooting is not fixing the bug and not so by wiping out the cache
    B1586874558230 likes this.
