10
Longer Dash cables
  1. N0_Klu3
    Gingerbread Jun 24, 2016
    N0_Klu3 , Jun 24, 2016 :
    Considering we need to use the surviving dash cables for greater charging, could you at least make some longer versions?
    I can barely reach when it's plugged in next to my bed!
    Archies, Andrizzy R, grk007 and 7 others like this.
  2. Steven Nouel
    Froyo Jun 24, 2016
    Steven Nouel , Jun 24, 2016 :
    I also found the cable to be a little short.. not sure if its required for dash speed charging performance but i think that the longer the cable the less power/more issues it could have based on personal experience.
  3. N0_Klu3
    garryo likes this.
  4. Loveit
    KitKat Jun 24, 2016
    Loveit , Jun 24, 2016 :
    Have you tried using another cable, say one from the OP2?
    Is there absolutely no benefit from dash charge with any other cable?
  5. Bram Haegeman
    Eclair Jun 24, 2016
    Bram Haegeman , Jun 24, 2016 :
    I second this, a 2m dash cable would be perfect. that's one of the only things still bothering me. Had a nexus 6 and a 3m monoprice standard micro usb for that, and it was, a little too long maybe ( :p ), but it was better, and able to use phone when charging.
  6. MarkusRanz
    Ice Cream Sandwich Jun 24, 2016
    MarkusRanz , Jun 24, 2016 :
    I tried to use a USB extension of 0.2m and that was enough to prevent dash charging, also these USB power meters prohibit the dash charger.... So for now a AC cable seems to be the only solution to get a longer total length from the socket...
  7. sfomin
    Nougat Jun 24, 2016
    sfomin , Jun 24, 2016 :
    it wasnt the usb extension distance that prevented dash charging, but the usb cable itself.
    Tokolozi likes this.
  8. 3rdschulz
  9. Pr0metheus2
    Donut Jun 25, 2016
    Pr0metheus2 , Jun 25, 2016 :
    USB 3.0 extension cable should do the trick. Haven' t tested personally, but don't use usb 2.0 extension cable, OP DASH cable requires more pinouts.
  10. N0_Klu3
    Gingerbread Jun 25, 2016
    N0_Klu3 , Jun 25, 2016 :
    Thought the dash cable was slightly thicker to allow more current through?
  11. pvsuru
    Eclair Jun 25, 2016
    pvsuru , Jun 25, 2016 :
    Cable is short. Normally cable does not come in so short length. Needs to increase the length in new version
  12. DongoDongo
    Eclair Jun 25, 2016
    DongoDongo , Jun 25, 2016 :
    I am worried about the length too since I need a couple in various areas.
    On the other hand, could we use the Dash Cable to connect to PC as storage?
    If I need to purchase another cable just for computer connection, can I just choose the normal USB Type-C cable?
  13. nmatheis
    US Brand Ambassador Jun 25, 2016
    nmatheis , Jun 25, 2016 :
    If you're plugging in for quick Dash charging, a short cable seems adequate. For overnight charging, I just use a regular old (and longer) micro USB cable with a type C adapter plugged into an old Qualcomm quick charger I had laying around at my bedside.
  14. N0_Klu3
    You can use the Dash cable to connect to PC, I ran some ADB commands using it last night with no issue.
  15. garryo
    Eclair Jun 25, 2016
    garryo , Jun 25, 2016 :
    On the subject of Dash cables, noone seems to have commented that the cable bindings with the phone is a round cross section cable but the separate accessory cable is the traditional OnePlus flat design. Go figure.
  16. garryo
    Eclair Jun 25, 2016
    SwiftKey seems to have autocorrected 'bundled' to 'bindings'
  17. sbooth
  18. Spliffman
    KitKat Jun 27, 2016
    Spliffman , Jun 27, 2016 :
    I agree 100%. At least with the OP2 I could by a third party compatible 6ft cable, but right now there are none for the OP3 supporting Dash charge.
  19. Pot Noodle
    Ice Cream Sandwich Jun 27, 2016
    Pot Noodle , Jun 27, 2016 :
    I got one of Amazon charges really fast as well it's very thick braided one begins with a K
  20. cb620
    Gingerbread Jul 5, 2016
    cb620 , Jul 5, 2016 :
    Link?
    It charges fast like fast/quick charging? I've used Google official usb-c chargers from my 6p and it charges slow. Normally 2-3 hours to fully charge whereas the dash charger only takes less than a hr for full charge.
