Looking for Cases and Tempered Glass via OnePlus 8 Pro Ultramarine Blue
  1. reza.jivani , via OnePlus 8 Pro Ultramarine Blue , Dec 29, 2020 :
    Hi all!
    I'm looking for the One Plus 8 Pro Case and also the Tempered glass (one that fits properly). Also a case for the OP buds. All of this in Ontario, Canada.
    Has anybody been able to find any of these items?
    I got a basic case from Amazon. But the Tempered glass is difficult to find.
  2. DRAS2019
    Honeycomb Dec 30, 2020
  3. SAIPRASAD.B
    Eclair Dec 30, 2020
    SAIPRASAD.B , via OnePlus 8 Pro , Dec 30, 2020 :
    For case I would suggest u to go with rhinoshield.com they have the best case for OnePlus phones and am also using for my device since last 3 months till now there is no issues with them..
    reza.jivani likes this.
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 30, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Dec 30, 2020 :
    Personally I use dBrand Grip case.
    When it comes to hardened glas it becomes abit tricky.
    I have tried Mocolo though. UV glued. Pretty nice but I wasn't that happy about the edges so I eventually removed it.
    Non UV glued are even harder to find a nice fit on and possible to use long term.
  5. RaZoRsLaSh
    Eclair Dec 30, 2020
  6. reza.jivani , via OnePlus 8 Pro Ultramarine Blue , Dec 30, 2020 :
    Hi! Thank you for sharing. Was it the Tempered one or gel based ones?
    SAIPRASAD.B likes this.
  7. reza.jivani , via OnePlus 8 Pro Ultramarine Blue , Dec 30, 2020 :
    Hi thank you for sharing. I've had the same problem with the UV light gel based ones. Plus the screen becomes really sticky. Couple of time in the pocket and they are done. Which one are you using now?
  8. #8
  9. RaZoRsLaSh
    Eclair Dec 30, 2020
    RaZoRsLaSh , via OnePlus 8 Pro , Dec 30, 2020 :
    It's tempered glass but is installed using a liquid solution and then cured with UV light
    I did get a bubble in the corner during installation, I guess I left a dust particle in there. but it sure not bother me since it's off to one side
  10. RaZoRsLaSh
    Eclair Dec 30, 2020
    None that I've noticed. Feels pretty responsive. Fingerprint scanner works well too.
  11. reza.jivani , via OnePlus 8 Pro Ultramarine Blue , Dec 30, 2020 :
    Awesome! I'm gonna give this and the rino shield one a try! Whichever works! 🤘 Thankfully the film that comes with it is still there.
  12. RaZoRsLaSh
    Eclair Dec 30, 2020
    Good luck. Watch a few tutorials on YouTube, and take your time with it.
  13. DrHuda
    Gingerbread Dec 30, 2020
    DrHuda , via OnePlus 8 Pro , Dec 30, 2020 :
    Can you share some photo
  14. DrHuda
    Is it okay to use without tampared glass
  15. SAIPRASAD.B
    Eclair Dec 30, 2020
  16. Swejuggalo
    Just the case. No screenprotection. Dropped it in asphalt a few times and no damages.
  17. Swejuggalo
    Arjun_Choudhry likes this.
  18. Does!Compute
    KitKat Dec 30, 2020
    Does!Compute , Dec 30, 2020 :
    For tempered glass, I tend to prefer Rhinoshield(though it is not glass per se) for curved screens, although other people's reviews may vary. I have either seen excellent reviews for it, or poor ones. It was superb on my colleagues 7 Pro.
    As for the cover, I tend to prefer OnePlus first party covers, Spigen or dbrand ones, depending on the phone size, weight and the cover's design.
    Hope it helps
  19. Tia859
    Eclair Dec 31, 2020
