11
Loop VR Opinions/Hacks/Controllers?
  1. Markus214
    Honeycomb Jun 6, 2016
    Markus214 , Jun 6, 2016 :
    Does anyone currently have double vision while using VR? Like if you close an eye it works on one side but when both eyes opened it displays two images on both lenses?
    Been playing around with QR codes trying to find best that works
    #41
  2. Galaejar
    Cupcake Jun 6, 2016
    Galaejar , Jun 6, 2016 :
    Using the second to last seems the best for me tough it's clearer when i set the loop just a little away from my nose which by the way hurts when using it for a couples of minutes :/
    #42
  3. Markus214
    Thank you! I have been switching between a few depending on the videos as well. Also trying to play with the switches inside like on the lenses.
    Next up ordering a bluetooth controller
    #43
  4. jimberkas
    KitKat Jun 6, 2016
    jimberkas , Jun 6, 2016 :
    tempted to order a controller as well. let us know what you decide to go with
    #44
    Markus214 likes this.
  5. AdeelSpeaks
    Gingerbread Jun 6, 2016
    #45
  6. Markus214
    Have you used that? How is it?
    #46
  7. Markus214
    Definitely will! Narrowed it down to 3 currently. Planning to be able to use it with phone when not in VR Mode as well as tablet
    #47
  8. run_dkc
    run_dkc , Jun 6, 2016 :
    Hey, does anyone know if there is a way to use the Loop VR app the play store says you device isn't compatible?
    #48
  9. Markus214
    I used the Google Cardboard app to set it up actually. I believe a lot of us did. For the QR Codes please feel free to use one of the QR Codes in the first post to help
    #49
  10. TheRealProcyon
    Jelly Bean Jun 6, 2016
    TheRealProcyon , Jun 6, 2016 :
    Mine probs comes in tomorrow
    #50
  11. run_dkc
    What do you do once you've downloaded the google cardboard app?
    #51
  12. Markus214
    Once you downloaded Google Cardboard you will follow the on screen instructions. When it says setup or look for QR code point your screen (the camera will open on screen) to the QR code you want to use
    #52
  13. Markus214
    I hope so! It's a really cool device once you get to play around with it. A little blurry but I think on OP3 or higher screen resolution devices will have better picture too
    #53
  14. TheRealProcyon
    Can't buy OP3, since I'm broke :(
    #54
  15. run_dkc
    Thanks so much it worked, now is there a way I can use Oneplus' app that they created for the launch?
    #55
  16. AdeelSpeaks
    AdeelSpeaks , Jun 6, 2016 :
    Yes,i have. its quite simple actually. You look at where you want to click, and click. For example on youtube 360 videos, you can't actually pause without taking out your phone. With this, you can simply look at the pause button (on the vr, in video) and click. :)
    That's how i suppose they will sell OP3 (idk for sure though). :)
    #56
  17. condemned
    condemned , Jun 6, 2016 :
    Mine is still pending and if they have no stock in eu ...wont get it for weeks. Dissapointed about the button tho. I recall a thread with a pic from their support that said there is one.
    #57
  18. TheRealProcyon
    Yes, they were giving false info
    #58
  19. sshafiee
    Cupcake Jun 6, 2016
    sshafiee , Jun 6, 2016 :
    I have a double vision too and i cant fix it. It's really annoying. Not even a YouTube video works well. Lost the count how long I tired to adjust the VR.
    What apps are you guys using?
    #59
  20. Markus214
    Which Device and QR code are you using?
    #60
