11
Loop VR Opinions/Hacks/Controllers?
  1. davkos
    Honeycomb Jun 10, 2016
    davkos , Jun 10, 2016 :
    Same here. PS I don't have a big nose lol
  2. condemned
    Gingerbread Jun 10, 2016
  3. The1Lion
    Marshmallow Jun 10, 2016
    The1Lion , Jun 10, 2016 :
    I tried fulldive and it has a setting for auto click. Also tried tightening the to strap to help with nose discomfort but makes it a bit blurry now.
    I'm charging my HTC One S to see how it'll work. My sandstone showed a bit of rubbing so didn't want it being scuffed up. The HTC fits a bit loose but it's not charged so waiting before trying it again.
  4. Markus214
    dreamcore likes this.
  5. Markus214
  6. Markus214
    Markus214 , Jun 10, 2016 :
    Ah I remember owning a HTC One X glad to see you still have your old HTC model. I love HTC Sense and actually have it throughout my OPO with the launcher and everything
    The1Lion likes this.
  7. The1Lion
    I actually rooted mine and have the CM nightly- actually updating it now as I post :D
    I would have been stuck on JB release otherwise.
    My HTC saved me during my RMA with my OPO.
  8. dreamcore
    Eclair Jun 10, 2016
    dreamcore , Jun 10, 2016 :
    Sure. This profile was created with a (Diztronic) case on, centered, with the "medium" IPD setting on each lens:
    62.0 mm
    63.25 mm
    dreamcore OnePlus Loop VR 52.0/64.5 v1[​IMG]IPD 64.5 mm
    65.75 mm
    67.0 mm​
    (The phone used is a OnePlus One, stock unrooted, 401/403 physical ppi, 480 logical dpi, if it matters.)
    The distortion coefficients have been massaged tenderly to provide the straightest lines my OCD could manage in a night.
    Movies, such as those accessed in Fulldive, should display L-R edge-to-edge using available resolution.
    Let me know how it works for you, or if you need another IPD.
    Markus214 likes this.
  9. Markus214
    I actually had the HTC One Sensation, X, M7, M8 I was going to continue with M9 and M10 but found OP
    I love their builds and phones
  10. Shafik Rahman
    Ice Cream Sandwich Jun 11, 2016
    Shafik Rahman , Jun 11, 2016 :
    I'm using Google voice access while watching videos in youtube it's tricky but it's better than pulling out the device and selecting next video.. Try this qr.. I don't know who created it but it gives good output in both oneplus one and two devices AntVR-QR-Code-qr_viewer_profile.png
  11. Markus214
    Honeycomb Jun 11, 2016
    Markus214 , Jun 11, 2016 :
    That's actually really clever using Google Voice to navigate to other video
  12. LucaP74
    LucaP74 , Jun 11, 2016 :
    Thanks, you make a great job bro!
    I've done almost the same, without removing screws. I just use some 3M magic tape to fix the inner magnet. It works.
    Not so beautiful like your solution, but very easy to remove.
    Only thing I don't like is that it works only on the left side, not in the right, the hand I use most.
    But amazon on Monday will deliver me a 7 euros bluetooth VR controller that other users have successfully tested, and I'm also going to try AirDroid trick.
    :p
    McMads likes this.
  13. dinjesk
    KitKat Jun 11, 2016
    dinjesk , Jun 11, 2016 :
    Can't you just turn the phone?
  14. Markus214
    Going to add to OP. Awesome guide!
    McMads likes this.
  15. LucaP74
    The problem is that most VR apps I've tested with OPO, when you turn smartphone downside, the whole VR scene turns in the right way, but for example setting popup comands from the gear icon, don't turn.
    It's true that should not be a big issue...I'll give a try ;)
  16. DKolev
    Froyo Jun 12, 2016
    DKolev , Jun 12, 2016 :
    Here is my mod to the annoying plastic which makes your nose hurt after a few minutes with the headset.
    Faktzi and Markus214 like this.
  17. condemned
    Gingerbread Jun 12, 2016
    condemned , Jun 12, 2016 :
    The nose hurts because the foam padding it too soft. I tried adding a strip of half a cm stronger polystyrene foam stuff to give it more height and it was enough (didn't add them permanently).
    AirDroid will allow you to control phone from PC - so no need to remove the phone all the time.
    I also noticed that you can see phone edges from the viewer (speaker/camera etc). Looks like it was designed with 6" in mind.
  18. LucaP74
    Honeycomb Jun 12, 2016
    LucaP74 , Jun 12, 2016 :
    Finally I tried to add magnets also on the right eye side, reversing the smartphone or leaving as it works with the left side magnets, but it doesn't work, only with left side magnets. Very strange
  19. LucaP74
    sorry bro, but I can't see the image of your mod :(
    ------chandu and dreamcore like this.
  20. Rahuvich
    Rahuvich , Jun 12, 2016 :
    Sorry but, anyone could help me on the "just flick the outside magnet and it registers as a button press.". I am not a native speaker and I've never heard of "flick". What does it mean? Ty!
