Losing signal
  1. andreinic
    Cupcake Nov 17, 2017
    andreinic , Nov 17, 2017 :
    I never had a phone who is losing cell signal. Didn't even think that it's possible.
    But now, with OnePlus5, the signal is constantly lost (I receive a message in the notification area to reconnect to the network), while I'm talking (and drop the call), while I'm walking...
    Than the network automatically reconnect.
    Otherwise is great.
    It's 2017, how is even possible to lose signal? This is basic stuff. [e]1f61e[/e]
  2. athaarv
    Jelly Bean Nov 17, 2017
  3. andreinic
    well, I think it's the phone. i still have an Samsung S6, Note 3, doesn't have any issue.
    never had a phone who is losing signal. this phone shouldn't be sold worldwide.
    thx for your answer.
  4. athaarv
    athaarv , Nov 17, 2017 :
    Make sure you're not blocking the antenna lines
  5. Star1ord
    Star1ord , Nov 17, 2017 :
    I too had a problem of network drops, talked to network providers they said there's no problem from their side and that is when I called OnePlus executive. He asked me to follow these steps -
    1. go to settings.
    2. backup and reset
    3. network settings reset.
    4. Press the reset settings button. (separately for both of the sim cards).
    5. Finally power off the device, eject the sim cards, put them back in and yes i didn't get the network drops again.
    fredy10 likes this.
  6. andreinic
    Cupcake Nov 18, 2017
    andreinic , Nov 18, 2017 :
    I've done that and wait to see what's happening. Thx for your answer.
  7. mazhar001
    Donut Dec 28, 2018
    mazhar001 , Dec 28, 2018 :
    Hi,
    I am also facing the exact same issue with OP5!! The signals just vanishes!!
    and most of the time people keep complaining that my phone is switched off!! even when I see signals on my phone!!
    This is not the issue with service provider!! I used the same sim in iphone and it works perfectly. I even changed to new sim but the problem still persists.
    This is the issue with OP5.
    Anyone has some solution?? Anyone facing the same issue??
    OP team please reply.
  8. Torpedo001
    Cupcake Dec 28, 2018
    Torpedo001 , Dec 28, 2018 :
    Which network carrier you are having? If issue is still persisting even after device reset. Try replacing sim card, probably sim card might be having some issues.
    Get sim card replaced by service provider.
  9. G_Amit_K_Pandey_amJU
    Cupcake Jan 4, 2019
    G_Amit_K_Pandey_amJU , Jan 4, 2019 :
    I too have been having these issues, I see the network bars, but call wouldn't connect or the call drop...
    had it on Oreo , even on Pie based OOS.
    I'll go for sim change and will confirm now..
  10. William_Tipping-Woods
    Cupcake Feb 2, 2019
    William_Tipping-Woods , Feb 2, 2019 :
    I'm having the same issue on my OP6. intermittent connectivity issues. definitely the phone. I've tried 3 different SIMs in it with the same problem, while those same SIMs work fine in other phones. I've done a factory reset and replaced my sim. Still no improvement....
    has anyone figured out how to sort this out?
  11. malik2105
    Cupcake Feb 3, 2019
    malik2105 , Feb 3, 2019 :
    solved??
  12. amalabhi
    Cupcake Jun 1, 2019
    amalabhi , Jun 1, 2019 :
    I am having the same issue with my one plus6T. I went to the service centre and they did a flash boot and now still the problem persist
  13. Waveform Modifier
    Marshmallow Jun 1, 2019
    Waveform Modifier , Jun 1, 2019 :
    Wrong forum
  14. amalabhi
    Cupcake Jun 2, 2019
  15. Waveform Modifier
    Marshmallow Jun 2, 2019
    Waveform Modifier , Jun 2, 2019 :
    Saids you. Network connection is by your provider and not OnePlus.
  16. amalabhi
    Cupcake Jun 2, 2019
    amalabhi , Jun 2, 2019 :
    Its not the network issue.. How come all the career networks fail!! And all these sim cards work perfectly in other phones.
  17. amalabhi
    Cupcake Jul 21, 2019
    amalabhi , Jul 21, 2019 :
    I saw your feed and I am also facing the exact issue. could you tell me what did you do to solve the issue?
