Lost app drawer icon, help!
  1. samnsrich
    Cupcake Sep 25, 2017
    samnsrich , Sep 25, 2017 :
    Somehow I have deleted my app drawer icon and it's messed up my home screen, how do I get it back?
    SalFlu likes this.
  2. nafiza.mamun
    nafiza.mamun , Sep 25, 2017 :
    No i think it happened to everyone generally. Mine also disappeared and it's a swipe up method now
  3. Hailfire101
    Froyo Sep 25, 2017
    Hailfire101 , Sep 25, 2017 :
    It's horrible. How can I get the app drawer button back?
    I hope OnePlus give us an option to have which ever on we want.
    This swipe up has put me right off this phone. If I wanted a pixel, I'd have bought a pixel.
  4. SalFlu
    SalFlu , Sep 25, 2017 :
    Same here, thought i did something wrong and have tried to fix it for half an hour. PLEASE get me my app drawer back i hate this one.
    samnsrich likes this.
  5. Rishi Panchal
    G_Scott_McManus_pHfs likes this.
  6. G_Charles_Schoonover_LfM
    kartik.a.gala likes this.
  7. Atzenman
    Froyo Sep 25, 2017
    Atzenman , Sep 25, 2017 :
    You can search in your apps under the settings menu and look for OnePlus Launcher. Then you have to uninstall the latest launcher updates. Maybe then you're getting back the Appdrawer icon. As an alternative you can use the Nova launcher or get used to the new swipe up gesture. Life goes on and software is getting better, that's how it goes.
  8. nitish.raajpal
    Froyo Sep 26, 2017
    nitish.raajpal , Sep 26, 2017 :
    It happened due to the latest 4.5.0 oxygen OS update. And the worst part is that ugly fat translucent bar at bottom and no option to make it transparent.
    For now you can't get it back. With negative feedbacks perhaps they give an option to choose either this or the old one later.
    F_Tony_M_Kitcher_PiEi likes this.
  9. nitish.raajpal
    Froyo Sep 26, 2017
    There is no option to uninstall updates for Oneplus Launcher. It has only disable and force stop. Never liked 3rd party launchers but it seems like would have to try now.
  10. Droid2drummer
    Froyo Sep 26, 2017
    Droid2drummer , Sep 26, 2017 :
    Install 3rd party launcher. Nova is great. This is the way of android system now.. I like it ..It took a minute to get used to but I like it.
  11. F_IDaniel_Delos_Santos_V
    Cupcake Sep 26, 2017
  12. samnsrich
    samnsrich , Sep 26, 2017 :
    actually this worked for me, after trying Nova, which I didn't like, I uninstalled the updates on one plus launcher (find the app in settings, click the hamburger in the top left) and bows I'm back to the original version.
    I turned off auto updates for it too. when I hear they have decent customisation options I'll try it out again.
  13. keithnyc
    Marshmallow Moderator Sep 26, 2017
    keithnyc , Sep 26, 2017 :
    You press on the three dots in the upper left hand corner after selecting the app and yes, it will bring back the drawer and the look of the original icons. But all your apps will need to be reset/reorganized into your home screen. If you're willing to do this, go for it. You can also disable future auto app updates by opening Google Play:
    1. Tap the hamburger icon (three horizontal lines) on the top-left.
    2. Tap Settings.
    3. Tap Auto-update apps.
    4. To disable automatic app updates, select Do not auto-update apps.
  14. nitish.raajpal
    Froyo Sep 27, 2017
    nitish.raajpal , Sep 27, 2017 :
    Are you guys using oneplus 5 ? I can't find any option to uninstall the update on OnePlus 3. Screenshot_20170927-045100.jpg
  15. madhedcity
    Cupcake Sep 27, 2017
  16. madhedcity
  17. Fursan Afzal
    Ice Cream Sandwich Sep 27, 2017
    Fursan Afzal , Sep 27, 2017 :
    use Nova then.
  18. G_Charles_Schoonover_LfM
    G_Charles_Schoonover_LfM , Sep 27, 2017 :
    I ended up doing just that.
    Liking it more than expected!
    For some reason I was thinking the gestures while the screen is off would stop working if I switched launchers from the OnePlus launcher, so I'm glad to see that's not the case.
    Fursan Afzal likes this.
  19. Maxmal
    Donut Sep 27, 2017
    Maxmal , Sep 27, 2017 :
    Can't stand fat gray bottom bar, and no more app drawer button! Who (anybody?) gives them feedback before they put out a new update? Will try different launcher, but what a pain!
    Hailfire101 likes this.
