4
Lots of bugs via OnePlus 8
  1. Achumohanraj
    Eclair Nov 1, 2020
    Achumohanraj , via OnePlus 8 , Nov 1, 2020 :
    Since i updated to oxygen os 11 stable via ota i cant download or install larger file from play store . It always says installation failed
    I cant update oneplus gallery and microsoft office app
    Please suggest me with some solutions
  2. Funk Wizard
    Moderator Moderator Nov 4, 2020
    Best Answer
    Funk Wizard , Nov 4, 2020 :
    Please clear cache and data for play store and play services and update after that, if the issue persists copy your data and do a factory reset, the device would work best if its factory reset once after every major android update.
  3. W1527802698983
    Cupcake Nov 2, 2020
  4. Vikas_robin
    Cupcake Nov 2, 2020
  5. Does!Compute
    KitKat Nov 2, 2020
    Does!Compute , Nov 2, 2020 :
    A solution for you:
    Use the search button before creating redundant threads. This question has already been answered on the forums.
  6. Achumohanraj
    Eclair Nov 2, 2020
    Achumohanraj , via OnePlus 8 , Nov 2, 2020 :
    Sorry its my mistake
  7. Does!Compute
    KitKat Nov 2, 2020
    On the same topic, do take a look at the forum rules. It will help you get solutions to your problems faster, and make it easier for you to navigate the forums
  8. Achumohanraj
    Eclair Nov 2, 2020
  9. pablofg1978
    Head Moderator Head Moderator Nov 2, 2020
  10. Dedovium
    Cupcake Nov 2, 2020
  11. #10
  12. Achumohanraj
    Eclair Nov 3, 2020
    Achumohanraj , via OnePlus 8 , Nov 3, 2020 :
    Try installing a larger size file frm google play u may get that bug sometimes😜
  13. Dedovium
    Cupcake Nov 3, 2020
    Dedovium , via OnePlus 8 , Nov 3, 2020 :
    I installed CODM and I didn't met this bug after 11 update
    Achumohanraj likes this.
  14. Dedovium
    Cupcake Nov 3, 2020
  15. Tidjon
    Cupcake Nov 3, 2020
    Tidjon , Nov 3, 2020 :
    it would be more friendly to just post the link to the previous existing thread.... just saying. in the end you helped no one.
    take care and be safe
  16. JRenex
    Eclair Nov 3, 2020
    JRenex , via OnePlus 8 , Nov 3, 2020 :
    Yes, Oxygen 11 has a lot of bugs, you will see more when you try to stroll around in your phone. Particularly making calls and connecting certain TWS brands like Haylou Gt1 pro and QCY T5 no sound produce when paired.
