"Low battery, the battery is too low. Charge for a while before power on!"
  1. JBH168 Eclair Aug 12, 2014
    JBH168, Aug 12, 2014 :
    I just updated to the newest version (OTA) of CM11S and now, I just get a screen saying "Low battery, the battery is too low. Charge for a while before power on!".
    My OnePlus One is plugged in, I can't tell though if it is charging.
    Fayazahamed likes this.
  2. saucy Jelly Bean Aug 12, 2014
  3. NikeimNetz Ice Cream Sandwich Aug 12, 2014
  4. TricksterTrick1231 Donut Aug 12, 2014
  5. JBH168 Eclair Aug 12, 2014
    how is this normal?
    that never happened to me before.
    My phone isn't booting anymore
  6. saucy Jelly Bean Aug 12, 2014
    saucy, Aug 12, 2014 :
    Happened to me when battery got too low and phone died. Plugged it in and it showed this message. Powered it on after a few minutes without issue. Have not received the ota yet though
  7. JBH168 Eclair Aug 12, 2014
    Thanks. Resolved itself after one hour of charging.
  8. Blachloq Gingerbread Aug 15, 2014
    Blachloq, Aug 15, 2014 :
    lucky you.. same situation.. but charging did not help (several chargers/cables).. had the same symptoms, now it seems to be dead => opening ticket
  9. greenhitman Froyo Aug 15, 2014
    greenhitman, Aug 15, 2014 :
    Are you charging your device via usb plugged into a computer or through a charging adapter through the wall?
  10. Blachloq Gingerbread Aug 15, 2014
  11. greenhitman Froyo Aug 15, 2014
    Sounds like it's probably the battery. Have you tried removing the battery then putting it back in?
  12. webvictim Donut Aug 28, 2014
  13. I5core Jelly Bean Aug 28, 2014
  14. Dexter Morgan Lollipop Community Expert Aug 28, 2014
  15. I5core Jelly Bean Aug 28, 2014
  16. webvictim Donut Aug 28, 2014
    webvictim, Aug 28, 2014 :
    It's not user-serviceable. To remove the battery you have to break the white security screw at the top right, which means that you'll void your warranty. That isn't a "removable battery" by any conventional definition.
    Dexter Morgan likes this.
  17. Robson KitKat Aug 28, 2014
    Robson, Aug 28, 2014 :
    You can, but you will probably void your warranty
  18. webvictim Donut Aug 29, 2014
    webvictim, Aug 29, 2014 :
    Well, the fix worked. Charge for 24 hours even though the phone does nothing and doesn't warm up, unplug for 12 hours, plug back in and leave it for an hour. I got the "low battery' screen for about 2-3 minutes when I plugged back in then it disappeared again. No light, no battery meter on screen but the phone warmed up. When I tried to power it on an hour later it worked fine.
    xaphor likes this.
  19. jarylw Donut Aug 31, 2014
    jarylw, Aug 31, 2014 :
    Has anyone had any success doing the 'fix' for 12/6 hours instead of the long 24/12 hrs wait? Cannot afford to have my phone down for so long..
  20. webvictim Donut Sep 3, 2014
