9
Low call volume (OnePlus 7)
  1. adarshmj2
    Donut Jun 11, 2019
    adarshmj2 , Jun 11, 2019 :
    Hi, I am experiencing low call volume (earpiece volume) even if it has set to maximum. I just want to know whether this is a common issue so that we can expect a fix as the team did it in OP6.
    Thank you.
    Regards,
    Adarsh
  2. caalapati
    Cupcake Jun 11, 2019
    caalapati , Jun 11, 2019 :
    I too facing the same issue in my new OnePlus 7, I am waiting for reply from OnePlus team.
    W1564999124536 likes this.
  3. Bananashoot
    Eclair Jun 11, 2019
    Bananashoot , Jun 11, 2019 :
    i havent faced that issue. its pretty loud for me. though i have to slide up a bit my phone when on ear than usual
    Suyash_Sarvate likes this.
  4. ruskin bond
    ruskin bond , Jun 11, 2019 :
    it's happening for me also, the sound is a bit distorted...must be due to those large speaker grills instead of the traditional one.
  5. G_shanmuga_R
    G_shanmuga_R , Jun 11, 2019 :
    i am also facing one plus 7 front speaker issue . audio from the front speaker is not clear and distorted .
    mudassarrauf and Suyash_Sarvate like this.
  6. mudassarrauf
    Froyo Jun 21, 2019
  7. adarshmj2
    Donut Jun 21, 2019
    adarshmj2 , Jun 21, 2019 :
    They have improved the call audio quality for OP7 Pro through last update. So hopefully we will be getting the same soon.
    mudassarrauf likes this.
  8. caalapati
    Cupcake Jun 21, 2019
  9. Markbeauchamp88
    Markbeauchamp88 , Jun 21, 2019 :
    Hi I have just received my OP7 this morning and the first thing I noticed was the really low call volume too, really needs to be sorted!
  10. RaduP
    Cupcake Jun 26, 2019
    RaduP , Jun 26, 2019 :
    Just had my first call on my new phone, and I was shocked at how low the in-call volume was! This needs to be fixed ASAP!
  11. W1559637584355
    Cupcake Jun 27, 2019
    W1559637584355 , Jun 27, 2019 :
    same issue here, tested the call quality over signal, whatsapp, skype, also with german mobile providers O2 and telekom, always in close proximity to a 4G antenna and for sure over my wifi with and withqut QOS.
    Don't get me wrong, I ******* love this phone (former iPhone 8 user), BUT the sound quality is not worth the other great experience , this MUST be improved !
    Does the 7pro has the same issues ?
  12. Skyheartblue
    Donut Jul 2, 2019
    Skyheartblue , Jul 2, 2019 :
    Having same low volume on calls issue with the 7 pro.
    LivL the phone but this is killing me...
    Need to be isolated during calls so no outside noise.
    Shahar
    sumitbhanot14 likes this.
  13. syyd
    Cupcake Jul 14, 2019
    syyd , Jul 14, 2019 :
    is there a fix to this issue ? I bought the phone 3 weeks back call volume is too low makes it difficult to hear the voice from the other side?
  14. H1562606960252
    H1562606960252 , Jul 14, 2019 :
    M facing issue while using speaker option. Other person is not able to hear me. Some times in normal mode too. One plus needs to Fix it ASAP
  15. syyd
    I am having issue with normal call not on loud speaker. Is there a known solution for this? if not, how do I proceed I'm new to the community..
  16. adarshmj2
    Donut Jul 14, 2019
    adarshmj2 , Jul 14, 2019 :
    Guys, I think, the earpiece volume is pretty good enough to hear the other end. Due to the placement of earpiece speaker, we are experiencing such issues. So if we hold the phone accordingly, that issue can be resolved. I know, this is not a long term solution. They have improved the quality (though I couldn't sense any) in last build. I still believe they have to come up with a solution.
  17. adarshmj2
    Donut Jul 14, 2019
    I don't have such issues.
  18. RobSchrijen
    Cupcake Jul 23, 2019
    RobSchrijen , Jul 23, 2019 :
    I also have very low volume when calling. I know the ear speaker works fine because when playing music on the phone both speakers (ear speaker and bottom speaker) produce sound. But when I'm calling the ear speaker volume goes to lowest and cannot be set higher.
    Any updates?
  19. H1562606960252
    H1562606960252 , Jul 23, 2019 :
    Other issues are also there. while making phone calls, it sometimes dials a video call and says, not available. Many a times it happens.
  20. J1563539976082
    Cupcake Jul 25, 2019
    J1563539976082 , Jul 25, 2019 :
