Low ear piece Volume On Call - OnePlus 3
  1. Hampa.Mahesh
    Cupcake Oct 10, 2017
  2. atty_57
    Donut Oct 10, 2017
    atty_57 , Oct 10, 2017 :
    the ear piece gets dirt clogged in it after usage hence changing it is the only option
    mahesh.hampa likes this.
  3. ashwin.243
    Honeycomb Oct 10, 2017
    ashwin.243 , Oct 10, 2017 :
    Hi
    I faced the same problem with my OnePlus 3. I went to the service centre and they told me that some dirt gets collected in the earpiece which creates this problem. Go to the service centre and they will solve it for you
    since my OnePlus 3 was out of warranty, they took ₹470 as a service charge from me
  4. yogesh1p3
  5. Tzachi Buchnik
    Cupcake Oct 11, 2017
    Tzachi Buchnik , Oct 11, 2017 :
    ***FIX***
    ok so i found the solution.
    the good news is that its easly fixable!
    but.. you will have to open your phone and do some technical stuff.
    the problem is dust in the ear-set.. BUT! it is hiding behind the black mesh and the rubber.
    to fix it..
    1-open your phone
    2-remove the motherboard (you can see videos on youtube about how to do that!)
    3-remove the earset
    4-remove the black rubber
    5-remove the black mesh
    now you'l see a lot of dust in the tiny hole that the sound should go throw!! that is the reason you cant hear...
    6- clean the dust with cotton and alcohol ( try to push the cotton with a needle inside and clean it good! )
    7 - close up your phone and ENJOY FULLY AND POWERFUL SOUND!!!
  6. dodisho
    Cupcake Oct 12, 2017
    dodisho , Oct 12, 2017 :
    the sound is only low in normal calls.. works fine and is perfectly loud in WhatsApp/Messenger/Viber or what ever calls.
    it's a bug, trust me!
