11
Low In-Call Volume in OnePlus 3T
  1. sameer4
    Eclair Dec 18, 2017
    sameer4 , Dec 18, 2017 :
    It happed after Oreo update.but not sure when.i'm barely able to hear what other person is trying to say even all volume slides are at max.
    nabsrai, glennr, micteg and 8 others like this.
  2. tango420420
    Cupcake Dec 18, 2017
    rautpunit likes this.
  3. domreplv
    Eclair Dec 18, 2017
    domreplv , Dec 18, 2017 :
    This is true.. For a second I thought it's was me... But I called the same number and spoke with the same person with my other phone and load and clear..
  4. Madhav9318
    Donut Dec 18, 2017
  5. JeungSeng
    Gingerbread Dec 18, 2017
    JeungSeng , Dec 18, 2017 :
    Pls use search function. This issue has been thr ever since.... Just flash the .zip in custom recovery and u are good to go
  6. JeungSeng
  7. pmjpraveen
    Donut Dec 18, 2017
    pmjpraveen , Dec 18, 2017 :
    It has happened with me as well. Go to the service centre n clean out the dust. It'll work back fine.
  8. sameer4
    Eclair Dec 18, 2017
  9. JeungSeng
    U may try it to confirm. I guess its the only fix so far...
  10. G_deepanshu_somani_VNwK
    Froyo Dec 18, 2017
    F_Anis_Rahman_yQfv and rautpunit like this.
  11. rautpunit
    Froyo Dec 18, 2017
    rautpunit , Dec 18, 2017 :
    same problem here. I posted many times about this but my post deliberately deleted by OnePlus coz I criticize OnePlus for their negligence. please raise this issue coz this is not hardware problem it's software problem.
  12. rautpunit
    Froyo Dec 18, 2017
    need root or.not???
  13. JeungSeng
    Nope. Need to unlock your bootloader first and then install twrp as custom recovery. Then flash the zip file via the twrp u have installed.
  14. G_juan_antonio_rodrigo_L
    Eclair Dec 18, 2017
    G_juan_antonio_rodrigo_L , Dec 18, 2017 :
    oneplus ha de solucionar esto con una actualizacion.
    la gente no tiene porque saber o querer rootear, saber que es twrp o el gestor de arranque.
    esto sucedió despues de una actualización oficial.
  15. sameer4
    Eclair Jan 17, 2018
    sameer4 , Jan 17, 2018 :
    not working.tried on OOS 5.0.1
  16. shubhamsingh55
    Honeycomb Jan 17, 2018
  17. S1532102467226
    Cupcake Jul 23, 2018
    S1532102467226 , Jul 23, 2018 :
    u can just clean the earpiece area from outside and it will be clear. no root required and nothing else. it seems they are dust prone.
    ashoknair likes this.
