Low internal storage.
  1. Me1256 KitKat Jul 18, 2015
    Me1256, Jul 18, 2015 :
    After deleting everything I possibly could, I end up with a lot less space than I expected. Is this normal? I am running the latest version of exodus, along with twrp. Also, although this is a pretty noobish question, how would I delete everything other than the OS, so I can have a completely reset installation? Thanks.
  2. Gingertwin984 Gingerbread Jul 18, 2015
    Gingertwin984, Jul 18, 2015 :
    It is normal because the phone requires so much space for the operating system. You could try resetting the phone if you want.
  3. Gonzo01 Lollipop Jul 18, 2015
    lostLambda likes this.
  4. joe1.joe2 Honeycomb Jul 18, 2015
    joe1.joe2, Jul 18, 2015 :
    Hold the power button and volume down while it's shut and it will prompt you with options and you would be able to delete everything
  5. Me1256 KitKat Jul 18, 2015
    Well, like an idiot I wiped the os. XD
    But... I had a back up so its fine. But how do I delete all of the extra data, and return my rom to a stock state. Right now, I have all of my downloads and apps from about 2 days ago. And even after doing a factory reset, all of that stuff is still there. So I need to know how to wipe all of my data of of there, but keep the os.
  6. Gonzo01 Lollipop Jul 18, 2015
    Gonzo01, Jul 18, 2015 :
    install twrp recovery and you can wipe all you want, just don't wipe OTG/USB.
  7. eranm5 Jelly Bean Jul 18, 2015
    eranm5, Jul 18, 2015 :
    That's better than good. Make sure your photos are backed up on the cloud.
  8. johnnymartz3 Jelly Bean Jul 18, 2015
  9. johnnymartz3 Jelly Bean Jul 18, 2015
  10. impure Ice Cream Sandwich Jul 18, 2015
    impure, Jul 18, 2015 :
    That's normal. And it annoys me to no end when devices with advertised 64GB have less than 64GB of usable space. Time to add that to my pet peeves list. And if you want to delete everything other than the OS in TWRP delete internal storage or something.
  11. Versed Honeycomb Jul 18, 2015
    Versed, Jul 18, 2015 :
    To bad there's no SD card, much easier to get yourself up and running with just re-installing the apps your need, and even more so for the data inside your apps, programs like AndChat can take time getting then all reset. A simple back up your server settings to the SD card saves time.
  12. Gonzo01 Lollipop Jul 18, 2015
    clean cache regularly. get cleaning app from play store. upload what you don't need daily to computer of flash drive. :)
  13. Gonzo01 Lollipop Jul 18, 2015
    internal storage is just like HDD in computer. if HDD is 1GB, you can never have the whole 1GB in use. Formatting it (which makes is usable) takes part of the storage space and there's nothing can be done about it. even if you have, let say, 64GB sd card, you don't actually have 64GB usable space. that's how things work. :)
  14. johnnymartz3 Jelly Bean Jul 18, 2015
    johnnymartz3, Jul 18, 2015 :
    19 GB is more than enough cushion for me. I'll start trimming things down once I get down to like 5 or 10 gb
  15. bicha Cupcake Mar 5, 2019
