3
Low Screenshot quality
  1. L1516899047434
    Donut Jul 19, 2018
  2. Liehjan
    Lollipop Jul 19, 2018
    Liehjan , Jul 19, 2018 :
    You can't, it's set to a default resolution.. is the quality bad in both normal and extended?
    L1516899047434 likes this.
  3. L1516899047434
    Donut Jul 19, 2018
    santhu001 and subham.patel like this.
  4. Liehjan
    That's a known issue with extended, but normal ones should be fine.
  5. MentalDraco
    Marshmallow Jul 19, 2018
    MentalDraco , Jul 19, 2018 :
    depends on how you send it, if you like mail it it will be just fine but if you send it as just a picture it will get compressed
  6. L1516899047434
    Donut Jul 19, 2018
  7. izzykasha
    izzykasha , Jul 19, 2018 :
    just convert it, loads of free apps to do this for you
  8. n00blit
    Honeycomb Jul 19, 2018
    n00blit , Jul 19, 2018 :
    Might be a bit dim, but what's the difference between normal and extended screenshots? I thought a screenshot is iust a screenshot?
  9. SCokart
    Gingerbread Jul 19, 2018
    SCokart , Jul 19, 2018 :
    this is because when you send it it becomes compressed it looks fine in gallery but sucks when you send it
    n00blit and NahbiCris like this.
  10. UltimateGamer07
    Eclair Jul 19, 2018
    I_am_Batman likes this.
  11. I_am_Batman
    KitKat Jul 19, 2018
    I_am_Batman , Jul 19, 2018 :
    Root.
    By rooting you can set the default screenshot format to png and it'll be of good quality!
    K1524295802494 and Chi Kin yip like this.
  12. L1516899047434
    Donut Jul 19, 2018
    L1516899047434 , Jul 19, 2018 :
    exactly
  13. L1516899047434
    Donut Jul 19, 2018
    Ok I will Google it... hope it does not complicate things
  14. I_am_Batman
    KitKat Jul 19, 2018
    If you read perfectly on how to root. It doesn't complicate things. If not, You'll face a lot of issues. Like boot loops and etc.
  15. jkb114
    jkb114 , Jul 19, 2018 :
    When you send it via Whatsapp or similar the apps will compress the image. a way around it is to share via google photos
  16. Sridhar Ananthanarayanan
    Sridhar Ananthanarayanan , Jul 19, 2018 :
    instead of sending as a picture, send it as a document and it will be fine. WhatsApp compresses them unnecessarily even if the original file itself is very small in size. don't know why they do that.
    subham.patel and L1516899047434 like this.
  17. Phi_
    Phi_ , Jul 19, 2018 :
    if you are rooted (and have some common sense in googling) there's a magisk module online called OP5T OPlongshot PNG which converts the .jpeg to .PNG of the entended screenshot. the file is on an XDA forum and you just have to download and flash in magisk.
  18. L1516899047434
    Donut Jul 19, 2018
    that's secondary when screenshot itself is saved in low resolution
  19. Sridhar Ananthanarayanan
    that module doesn't convert jpeg to png. because that won't help. the module modifies the system code so screenshots are generated in png.
    also, what if the device isn't rooted?
    you talk of common sense without due considerations. how much common sense does that make?
  20. Sridhar Ananthanarayanan
    i gave you an alternative that addresses the requirement.
