low voice
  1. Sudarshan Salvi
    Cupcake Aug 5, 2018
    Sudarshan Salvi , Aug 5, 2018 :
    Using one plus 3T since one & half year.
    phone is working properly.
    From 2 days having issue with earpiece voice.
    low voice delivery.
    please solve this issue if it is of software problem.
    9038997358 likes this.
  2. Nikhil_Thadani
    Froyo Aug 5, 2018
    sarayevo and F_Ashutosh_Mal_tHsO like this.
  3. G_Viru
    Jelly Bean Aug 7, 2018
  4. G_Viru
  5. Eng.alnajjar
    Cupcake Aug 7, 2018
  6. Hussar10a
    Eclair Aug 7, 2018
    Hussar10a , Aug 7, 2018 :
    After 2 years with my 3 I had exactly this immediately after I downloaded 5.0.4 and because of that was absolutely convinced it was a software problem.
    I live in a not dusty part of the world so discounted the blocked grille theory that comes up on this forum.
    Toothbrush did nothing, isopropyl alcohol did nothing, so with nothing to lose I got a needle and gently poked out the holes in the mesh then vacuumed the grill.
    Result? Absolutely perfect sound, the level was so high I had to reduce the volume! I guess sweaty old ear flaps mixed with pocket dust over a period of time had slowly clogged up the grille and I'd just kept increasing the volume to compensate!
    For me at least, it was dirt not software, and my phone's like brand new again.
    Nenadd, Sudarshan Salvi and Nick 59 like this.
  7. Samuel.Ejiaga
    Cupcake Aug 7, 2018
  8. G1533667635529
    Cupcake Aug 7, 2018
    G1533667635529 , Aug 7, 2018 :
    Very low voice of caller is heard on my handset one plus 3 Tried volume increase but still can't hear properly on receiveing calls.
    Please help
  9. Paschfire
    KitKat Aug 7, 2018
    Paschfire , Aug 7, 2018 :
    Clean the earpiece speaker grill, dirt is the most common reason for this issue.
  10. programmer01001
    Cupcake Aug 8, 2018
    programmer01001 , Aug 8, 2018 :
    Preacher here...
    It's not a hardware or software issue, well it is hardware but not factory legacy. You just need to clean contact pads between speaker and motherboard. All the oils and moisture gets it gunked up, so conductivity is low.
    I'm out, amen.
  11. G_girish_kumar_jtDD
    Cupcake Mar 11, 2019
    G_girish_kumar_jtDD , Mar 11, 2019 :
    hi guys I too had same problem till now and just now contacted customer care and they suggested to do following steps to clear cache as below. issue resolved for me.
    1. shutdown mobile
    2. hold power button and volume low buttons for 10 sec.
    3. select language as english
    4. click on 'wipe data and cache' option
    5. again select only 'wipe cache' other wise data will be lost.
    6. click on 'yes' and then 'reboot'
    issue resolved. njoy
    I1552458344553 likes this.
  12. B1548336461471
    Cupcake Mar 12, 2019
    B1548336461471 , Mar 12, 2019 :
    dirt is not the reason as this has been experienced after a software update, sad thing is that oneplus couldn't figure out what is the issue. because of this issue its my last oneplus device
    S1552656608742 likes this.
  13. elroyclark
    Gingerbread Mar 12, 2019
    elroyclark , Mar 12, 2019 :
    When I owned a op3t, I too had the same issue and it too seemingly happened after an update..... I ranted and raved, blamed God and sunder lol
    Issue was resolved when I cleaned the earpiece as others in this post have alluded to.
    Clean the earpiece.
  14. B1548336461471
    how did you clean it
  15. elroyclark
    I actually disassembled the phone and vacuumed the earpiece from both sides. But as someone earlier said, very gently using a needle and a vacuum will work as well.
  16. B1548336461471
    thats involve risk. anyways thanks
  17. I1552458344553
    Donut Mar 13, 2019
    I1552458344553 , Mar 13, 2019 :
    Ok so i am gonna try clearing cache for now because I am really not sure how can I clean earpiece without damaging my phone.
  18. R1552067412176
    Cupcake Mar 13, 2019
    R1552067412176 , Mar 13, 2019 :
    It turned fruitful for you or not...?
  19. R1552067412176
    Regarding point 4 & 5... Which data is it?
  20. I1552458344553
    Donut Mar 13, 2019
    Gonna try later today. Will update here.
