4
Sound Low volume when calling
  1. G_Thomas_S_PyvV
    Honeycomb Sep 17, 2018
  2. peppeallsell
    Donut Sep 18, 2018
  3. G_Thomas_S_PyvV
    Honeycomb Sep 18, 2018
    G_Thomas_S_PyvV , Sep 18, 2018 :
    I really don't know... Maybe they will ask you to reset your phone first, but I read in forums that it doesn't solve the problem. And it's a pain in the a@@ to download/set/... everything again
  4. G_neeraj_jain_NVCB
    Cupcake Oct 9, 2018
    G_neeraj_jain_NVCB , Oct 9, 2018 :
    I have the same problem for last one month. I tried reset phone but no help. Only solution available is to root the device and do some file change. Please help.
    Superfurry likes this.
  5. hsbhatia
    Cupcake Dec 15, 2018
    hsbhatia , Dec 15, 2018 :
    Did you get any resolution? Tried taking the issue directly with oneplus as a complaint?
  6. X1544930886185
    Cupcake Dec 16, 2018
  7. hsbhatia
    hsbhatia , Dec 16, 2018 :
    Seems like a common issue. And I thought it must be hardware dying on me. How long you have been encountering the issue ?
  8. Paschfire
    KitKat Dec 16, 2018
    Paschfire , Dec 16, 2018 :
    If you're referring to the earpiece speaker volume, then call a OnePlus service center and have the earpiece speaker and grill cleaned, or even replaced. 9/10 times it's sweat, dust, dirt and dead skin cells clogging up the speaker assembly.
    This has been reported in many cases to have solve the problem.
    Seen within this thread are actual photos showing the dirt build up causing the issue with low earpiece speaker volume.
    https://forums.oneplus.com/threads/low-voice-volume.946561/
  9. X1544930886185
    Cupcake Dec 17, 2018
    X1544930886185 , Dec 17, 2018 :
    since long maybe a year.
  10. hsbhatia
    Cupcake Dec 18, 2018
    hsbhatia , Dec 18, 2018 :
    Hey, thanks I will consider that. Looking at numerous others having the same problem I was convinced it is a software issue and prefer not to send the phone if its actually not hardware issue. Moreover, it was suddenly changed, not over a course of time But let's see.
  11. Mohammad
    Froyo Dec 19, 2018
    Mohammad , Dec 19, 2018 :
    Hi
    many users don't like to root their mobiles me too so OPO must have a software Solution or any thing is reasonable
    I real start to heat the mobile and any thing with OnePlus LOGO
  12. tnttrx
    Froyo May 4, 2020
    tnttrx , May 4, 2020 :
    I have opened my second hand 3T and saw that display was loose on the top. That was the way for dust to come in and the earpiece grill was full of dust from the INSIDE!
    Everything works great once I have cleaned the grill and glued display back again.
    BTW, is it common for 3T display to glue off on the top of the screen?
    How could I recognize if display is the original one or not?
  13. Mehr7400
    Cupcake Jul 31, 2020
    Mehr7400 , Jul 31, 2020 :
    I finally fixed this problem!
    The problem with this low volume of this phone is not because of the software
    There is a hardware problem
    To solve this problem, you need to open the phone and open the phone speaker
    There is a net under the speaker (like the picture below)
    You have to remove it
    A lot of dirt has accumulated under this net
    Clean it
    Done
    Close the phone and enjoy
