7
Other Low volume with Airpods
  1. antonim
    Donut Oct 18, 2019
    antonim , Oct 18, 2019 :
    Same issue here with 6T. I even tried to rollback to 9.0.16 but no chance since unrooted. Any solution on the horizon?
    Ezaz09 likes this.
  2. Ezaz1990
    Cupcake Oct 18, 2019
    Ezaz1990 , Oct 18, 2019 :
    I am facing the same issue. I was going to downgrade it to 9.0.16 but after reading your comment i will have think about it. If there is no solution then better not to waste my time. Oneplus i hope you are reading this. So many ppl are facing this issue. Kindly come up with a solution.
  3. Ezaz1990
    I am facing the same issue with my airpods. But my friend's airpods are working fine with my Oneplus 6t. So I don't know if the problem is with the airpods or the compatibility problem between airpods and oneplus
  4. N1571271723802
    Cupcake Oct 19, 2019
    N1571271723802 , via OnePlus 5T , Oct 19, 2019 :
    This solution worked great for me and now I have a loud volume when it's a little over half way of the max volume
    00Goks00 likes this.
  5. 00Goks00
    00Goks00 , via OnePlus 6 , Oct 19, 2019 :
    press the button on the back of AirPods till the light blinking turns red and reset it..give it another try...this happened because connecting between Android and ios messes up the max volume
  6. Ezaz1990
    Ezaz1990 , Oct 19, 2019 :
    I have updated my Oneplus 6T with beta version of Android 10. It works. The original sound volume is back on my airpods. Just try it.
  7. antonim
    Donut Oct 19, 2019
    antonim , Oct 19, 2019 :
    I thought about it, but shall I be rooted again to make it? I am not sure the instalation process while full stock unrooted. As well I read few people got soft bricked.
  8. Ezaz1990
    Cupcake Oct 20, 2019
    Ezaz1990 , via OnePlus 6T , Oct 20, 2019 :
    You just need to download the beta version of Android 10 and copy it to the root folder. Go to setting - system update - press the setting icon on the top right - press on local upgrade and install the same. Nothing will happen to your existing data. It is a normal OTA upgrade.
    Beta version might have some bugs. Till now it is working fine for me.
    https://oxygenos.oneplus.net/OnePlus6TOxygen_41_OTA_060_all_1910081734_759171f133294ef4.zip
    Let me know if any more queries.
  9. antonim
    Donut Oct 20, 2019
    antonim , Oct 20, 2019 :
    Oh local upgrade then, I thought it need to be flashed via twrp, anyway thank You for instructions, but I might wait a bit for some updates tho.
    Ezaz09 likes this.
  10. mohawahba
    Gingerbread Oct 25, 2019
    mohawahba , Oct 25, 2019 :
    It's true, I can confirm I have the same issue with my aipods 2 since that Damn update. I doubt oneplus did it on purpose to force sales of their bullets which is not wireless. They pushed two updates since then and no fix coming for it. I tried in on different android phones and it works as loud as on iPhone. So basically it is a software bug that should be reported to oneplus..
  11. mohawahba
    Did you fix it the issue?
  12. zerobeatpro1
    Eclair Oct 26, 2019
    maxispin and mohawahba like this.
  13. atzaruri
    Cupcake Oct 29, 2019
    atzaruri , Oct 29, 2019 :
    I have a OnePlus 6T on the Android 10 beta. I've tried multiple times the Forget, Reset & Repair, also with and without Sync absolute volume and it didn't work, but I manage to fix them, at least for the moment, by connecting them to my iPad, raising the volume to maximum, and then connecting them to my One Plus. They seem to work ok now, even after I've connected and disconnected them from my One Plus multiple times in the last 24 hours.
    zerobeatpro1 likes this.
  14. mohawahba
    Gingerbread Nov 2, 2019
    mohawahba , Nov 2, 2019 :
    i have done that no luck, I ended up selling it
  15. abdullahz86
    Cupcake Nov 4, 2019
    abdullahz86 , Nov 4, 2019 :
    I have one plus 6 and I have the same issue, my airpods worked perfectly fine until about few weeks ago and now the volume is just not loud enough. I have tried everything on this thread *multiple* times and no luck. One plus should really fix this issue it's really frustrating
  16. Luismi Calleja
    Cupcake Nov 5, 2019
    Luismi Calleja , Nov 5, 2019 :
    I had got every oneplus since oneplus 3T.
    That was the last phone wich had a good sound volume over bluetooth or even minijack with the usb-c cable.
    You may find a hundred of threads in this forum.
    You may also check it, pluging it to a sound reciver with EQ graphical lines (check it with both BT and cable). At max power the oneplus 6T only have a line or two (5-10%) of input power, so the volume is pretty low
    Its a crap.
  17. maxispin
    Cupcake Nov 5, 2019
    maxispin , Nov 5, 2019 :
    Reset the Airpods is the right answer. Thanks!
  18. J1552148844429
    Cupcake Nov 6, 2019
    #38
    ahm4 likes this.
  19. D1575848117504
    Cupcake Dec 8, 2019
    #39
  20. D1575848117504
    Cupcake Dec 8, 2019
    #40
