15
lowest volume for is still way too loud?
  1. bollandk
    Cupcake Jun 11, 2019
    bollandk , Jun 11, 2019 :
    on the lowest volume (for media) i still feel it is anything but discrete. only alternative is headphones. but other phones can be put on a much lower volume, so should be possible with an update?
  2. DeathMoJo
    Gingerbread Jun 12, 2019
    DeathMoJo , Jun 12, 2019 :
    Are you talking about media volume? I would agree. Kind of wish there was a 1 speaker option as well.
    Oj-Senior and EmielBoon like this.
  3. MichiMess
    Eclair Jun 12, 2019
    MichiMess , Jun 12, 2019 :
    Yes please fix it! It's way too loud. Apps, ringtones and alarms. Please fix it!
    Oj-Senior, EmielBoon and bollandk like this.
  4. bollandk
    Cupcake Jun 12, 2019
    bollandk , Jun 12, 2019 :
    yes indeed, i mean media volume : )
    EmielBoon likes this.
  5. Syaoran
    Syaoran , Jun 12, 2019 :
    Personally, I think the ringtone volume needs to be a little louder. You can always adjust the volume of the media you are watching through the player to further lower the volume to a level you are happy with.
  6. dsmonteiro
    Community Consultant Staff Member Jun 12, 2019
    dsmonteiro , Jun 12, 2019 :
    Please go to settings and search for "hearing aid compatibility" and check if that option is enabled. If it is, disable it.
    Report back afterwards.
  7. MichiMess
    Eclair Jun 12, 2019
    There is no option like that
  8. B_Wrath
    Nougat Jun 12, 2019
    B_Wrath , Jun 12, 2019 :
    It will be under the accessibility settings.
  9. MichiMess
    Eclair Jun 12, 2019
  10. B_Wrath
    Nougat Jun 12, 2019
    Can you post a screenshot of your accessibility settings?
  11. MichiMess
    Eclair Jun 12, 2019
  12. B_Wrath
    Nougat Jun 12, 2019
    That's new. It has always been there. Probably someone with a OnePlus 7 Pro can check it.
    Anyways, does your audio volume increase or decrease when you press the volume keys?
  13. ariel.us
    Froyo Jun 12, 2019
    ariel.us , Jun 12, 2019 :
    having the same issue.
    but with the calls. cannot change the volume, no matter what i do. i see the phone when i press the volume, but the keys control the media. i manually move the slider, does not change, no matter if i try to increase or decrease (that's the lowest it goes for phone).
    Also, when i go to the settings, the call volume is not there
    Please notice on both screenshots, i'm in a call at the moment
  14. MichiMess
    Eclair Jun 12, 2019
    hmm that's another issue. I don't have this issue
    ariel.us likes this.
  15. ariel.us
    Froyo Jun 12, 2019
    You are right.
    It's a similar issue
    but i also have the same issue you mean, like the lowest volume for media is still to high, let's say.. if we have 20 steps for volume, the step from 0 (mute) to 1 is way too big
    MasDhani, Lecalius, Oj-Senior and 2 others like this.
  16. MichiMess
    Eclair Jun 12, 2019
    Oj-Senior likes this.
  17. Tiemsch
    Donut Jun 14, 2019
    Tiemsch , Jun 14, 2019 :
    Can confirm for 1+7 Pro. Please lower the min volume for external speakers!
  18. number_512
    Donut Jul 16, 2019
    number_512 , Jul 16, 2019 :
    I agree with all of the above. The lowest volume is still uncomfortably loud.
    I have been searching high and low to find an app to fix this, so far without much success.
    Oj-Senior, EmielBoon and Tiemsch like this.
  19. Tiemsch
    Donut Jul 16, 2019
    Tiemsch , Jul 16, 2019 :
    I nearly gave up all hopes that OnePlus will fix it. You can find threads like this since the OnePlus 3, but nothing happened.
  20. Discostu
    Jelly Bean Jul 16, 2019
    Discostu , Jul 16, 2019 :
    Unbelievable. OnePlus add dual speakers after being hammered for the last year because they didn't offer it. Now that it is offered - people want the option to disable one speaker because it is too loud.
    OnePlus will never win.
