15
lowest volume for is still way too loud?
  1. ariel.us
    Froyo Jul 17, 2019
    ariel.us , Jul 17, 2019 :
    Please read. I'm talking about headphones, and mainly on calls.
  2. Discostu
    Jelly Bean Jul 17, 2019
    Discostu , Jul 17, 2019 :
    I did read and I was referring to the original poster and 1st reply who say that the "media volume is too loud and not discrete enough", that the only solution is "a headphone" and "wish for the option to use 1 speaker", respectively.
    ariel.us likes this.
  3. J1544832521510
    Cupcake Jul 17, 2019
    J1544832521510 , Jul 17, 2019 :
    You should have volume buttons on left side of your phone to lower the volume.
  4. J1544832521510
    Go to your settings and click sound and click on audio tuner and turn on the enable audio tuner on the first thing showing there and if you unable to then plugin your headphones, (Just so you can set the bars of equalizer for your volume. Then you can remove headphones after you set the volume.) That should fix your problem.
  5. ariel.us
    Froyo Jul 17, 2019
    Missing the audio tune option. Maybe is not a op7 feature?
  6. leanderlagervret
    Cupcake Aug 17, 2019
    leanderlagervret , Aug 17, 2019 :
    Hey guys,
    Is there any update on this issue?
    It seems like there are settings options on the 7+ that are not there for the 7?
    Has anyone managed to find a fix for the loudness issue? Currently the headphones are not really usable!
    Thanks a lot
  7. HellsDelight
    Froyo Sep 10, 2019
    HellsDelight , Sep 10, 2019 :
    On my OnePlus 3 the low volume was much lower than on the 7 pro on speakers with media. With the Android 9 update on op3 it was unchanged and fine for me.
    I tried the app precise volume but on lowest volume it's unchanged with this app.
    I don't say the volumes should be lower at all like other manufacturers lower volumes in general to be in line with hearing damage regulations in some countries. I just want some more lower steps for sleeping radio like it was possible with the op3.
    Or is there another app that could help?
  8. nickelbers
    Cupcake Nov 2, 2019
    nickelbers , Nov 2, 2019 :
    I have the same issue on my OP7T. The lowest level of media and call volume are too loud!
    OP please fix this!
  9. Jason_FIN
    Cupcake Nov 30, 2019
    Jason_FIN , Nov 30, 2019 :
    I agree - lowest volume setting is too high for listening on a quiet place. E.g. Samsung has better control for volume.
    Lecalius likes this.
  10. E1576915721423
    Cupcake Dec 31, 2019
    E1576915721423 , Dec 31, 2019 :
    I was having the too loud issue for call when kept on low volume. When I see this thread I checked hearing and aid compatibility under accessibility and turned it off and guys it worked for me. Now I can talk with compatible volume, and even I can change the volume level
  11. V1578047295729
    Cupcake Jan 3, 2020
  12. sandiplokh
    Cupcake Jan 7, 2020
    sandiplokh , Jan 7, 2020 :
    go to setting > sound> use personal setting profile sounds( switch on )
  13. Z1594458092684
    Cupcake Jul 11, 2020
    Z1594458092684 , Jul 11, 2020 :
    Found a roundabout solution on 7t pro:
    Instead of wondering about fiddling with the basic volume setting, lower hertz levels with an equalizer. Many music apps provide it (I use Muzio player) and it allows all the volume control you need.
    Just be careful not to let ears explode on another apps since this solution leaves the main media volume higher than normal.
  14. A1607346667565
    Cupcake Dec 7, 2020
    A1607346667565 , Dec 7, 2020 :
    I have the same problem with my Oneplus nord. The lowest volume is way too loud. Is there any way to fix this?
  15. JulianAB6
    Froyo Dec 10, 2020
  16. L1572886027953
    Cupcake Jan 4, 2021
    L1572886027953 , Jan 4, 2021 :
    2021, and they are still having no fix whatsoever to this annoying small bug. Or is it a HW issue to produce less loud sound? In any way, missing aux and having this way too minimum loudness level issue are making this phone to be me first and last OP. Sadly.
  17. R.Peter
    Ice Cream Sandwich Jan 5, 2021
