57
Theme Macro & Wide Angled lense tips, questions and shots
  1. script
    Nougat Moderator Oct 8, 2017
    script , Oct 8, 2017 :
    Merged, here you'll find info
    Ash645 likes this.
  2. G_tech_key_guru_HgLG
    Donut Oct 8, 2017
    script likes this.
  3. G_tech_key_guru_HgLG
    Donut Oct 8, 2017
  4. script
    Merged into the „main“ main thread.
    Usually you'll find any kind of extra lenses in online shops like Amazon. Google will help you.
  5. G_tech_key_guru_HgLG
    Donut Oct 8, 2017
    G_tech_key_guru_HgLG , Oct 8, 2017 :
    I mean ,since op5 dual camera set up is different from others. so which one will be better for this device.
  6. Mr. BG
    Marshmallow Oct 8, 2017
    Mr. BG , Oct 8, 2017 :
    For a tech guru you sure have a lot of questions, as @script already mentioned, why don't you ask the Google Guru?
  7. ajshanker
    Ice Cream Sandwich Oct 9, 2017
    ajshanker , Oct 9, 2017 :
    I use a similar $3 clip on lens from amazon for Macro, combined with op5's 2x zoom Some exceptional shots are possible.
  8. ajshanker
    use any clip on lens. clip it to the 1st lens as that does majority of shooting, if you use 2x it might jump from one lens to the other under good lighting. I would
    still suggest you to clip it to your first lens as the quality of images from the f1.7 lens is significantly better.
  9. bharathpsd
    Gingerbread Nov 12, 2017
    bharathpsd , Nov 12, 2017 :
    besides universal, is there any other lenses that we can get like 'Moment' for Pixel ?
  10. Punk_69
    Lollipop Nov 12, 2017
    Bouncer71, George Mallia and script like this.
  11. Punk_69
    Punk_69 , Nov 12, 2017 :
    Try Aukey
    They're great, according to the YouTube reviews
    Bouncer71 and ajshanker like this.
  12. George Mallia
    Cupcake Nov 20, 2017
    George Mallia , Nov 20, 2017 :
    Hi,
    Any mobile photography enthusiats? Does anyone know about good oneplus 5 lens add-ons tried and tested?
  13. script
    Nougat Moderator Nov 20, 2017
    script , Nov 20, 2017 :
    Merged, here you'll find info, hopefully
  14. O1514822293757
    Ice Cream Sandwich Jan 3, 2018
    O1514822293757 , Jan 3, 2018 :
    can u name the company of the lens u r using.can u post pics for u r clipping onto the first lens only without any interference on the 2nd lens camera body.
    I am using the 5T
  15. MGreyWolf
  16. O1514822293757
  17. MGreyWolf
    MGreyWolf , Jan 3, 2018 :
    all set in auto except the focus. and one more tip, have a very steady hand :)
    rrajax and O1514822293757 like this.
  18. O1514822293757
    manual mode,
    all auto except focus,
    was focus set on macro
    what abt the zoom....did u use any
  19. MGreyWolf
    no zoom used. I think it will degrade the quality. My subject is really nice & steady. ;-)
  20. MGreyWolf
    ajshanker likes this.
