3
Major issue regarding the notch!!!
  1. hemanth malgari
    Cupcake May 25, 2018
    hemanth malgari , May 25, 2018 :
    The displaying issue besides/through the notch.
    The main problem with the notch is.. suppose your watching a story in WhatsApp,the name of the person cnt be seen completly,as goes through the notch!
    And suppose u hide the notch area.. in every application,the area hided by the notch cant be seen.
    And suppose ur playing a vedio in youtube the vedio doesnt come full screen,as it plays like ur hiding the notch area! but not beside the notch!
    i expect a bug fix for this issue!
    tomere, Singlanubhav19 and turbo63 like this.
  2. Gav_W86
    Starting Point Expert May 25, 2018
    Gav_W86 , May 25, 2018 :
    it will be that way until apps support the notch idea...
  3. FaleshC
    KitKat May 25, 2018
    FaleshC , May 25, 2018 :
    as far as i can tell its WhatsApp's fault bcz it doesnot support the notch. maybe in later version notch support will come.
    Singlanubhav19 and Hasan Khawari like this.
  4. hemanth malgari
    what about the ios!? it doesnt happen like this if its the application problem!
    Hasan Khawari likes this.
  5. Inflatedtitan
    Inflatedtitan , May 25, 2018 :
    That's a totally different animal bro... Two totally different operating systems, on two different phones.... Also the iPhone X been out longer so I'm sure the app dev had plenty of time to make the app compatible with it..
  6. outpin
    Honeycomb May 25, 2018
  7. DevonT
    Gingerbread May 26, 2018
    DevonT , May 26, 2018 :
    I thought there was a setting that allows to enable or disable fullscreen support for certain apps that don't cooperate well with the notch.
  8. anupritaisno1
    KitKat May 26, 2018
    anupritaisno1 , May 26, 2018 :
    There's no way. Support for notches is planned in android P
  9. DevonT
    Well Android P isn't official yet. I'm going by the current stable release.
  10. Hasan Khawari
    Hasan Khawari , May 26, 2018 :
    As far as I can tell OnePlus can turn the notch on our off but it is the app developer who is responsible for what the app does with the notch?
  11. Hasan Khawari
  12. FaleshC
    KitKat May 26, 2018
    FaleshC , May 26, 2018 :
    DevonT
    I thought there was a setting that allows to enable or disable fullscreen support for certain apps that don't cooperate well with the notch.​
    as far as i know there is setting to force app to go full screen but in that case it should natively support the notch. full screen means it will cover whole area and notch will be more prone to block things if the app is not developed for notch area.
    hemanth malgari likes this.
