170
Malaysia OnePlus Fan Club
  1. Scann69
    Honeycomb Aug 6, 2014
    finaldentiny likes this.
  2. jeehinwong
    kampuamee likes this.
  3. vintcf
    KitKat Aug 6, 2014
  4. kampuamee
    Lollipop Aug 6, 2014
    kampuamee , Aug 6, 2014 :
    Good luck bro, everything will be ok ;)
  5. finaldentiny
    Community Veteran Aug 6, 2014
  6. Wengg
    Ice Cream Sandwich Aug 6, 2014
    Wengg , Aug 6, 2014 :
    An update after a few days. Really enjoyed the phone so far, superb display and above average camera. Ui is clean and organized, the phone feels great in my hand.
    However, I just encountered a minor issue. In the pull down notification bar, I cannot adjust whether it's normal, vibrate or silent mode. Once I tap from normal, it will turn to vibrate, one more tap, to silent. From then on, I cannot change the mode anymore no matter how long I tap (gets stuck in silent mode unless I manually go to settings)
    Also, the camera occasionally fails to load and I had to reboot.
    pgneo likes this.
  7. maomaogong
    Eclair Aug 6, 2014
  8. Scann69
    Scann69 , Aug 6, 2014 :
    Look at my signature :cool:
    I've tried 3 others......
  9. fishysong
    fishysong , Aug 6, 2014 :
    bro, is below consider other ROM?
    What type of recovery do you want to flash?
    1. TWRP
    2. CWM
    3. PhilZ' CWM
    4. Stock
  10. nsync79
    nsync79 , Aug 6, 2014 :
    Fascinating, reading up on post #1 on how to mod, a bit reserved as never done before
  11. kampuamee
    I like this kind of movies. May go for it if got time. Thanks.
    jeehinwong likes this.
  12. vintcf
    KitKat Aug 6, 2014
    vintcf , Aug 6, 2014 :
    ColorOS?
  13. finaldentiny
    finaldentiny , Aug 6, 2014 :
    haha!i see....many handphone ooo~
    nice ma colorOS?compare to CMS11~
  14. Scann69
    There's some setting for the volume toggle i recall.
    What camera app are you using? CM ROM?
  15. jeehinwong
    jeehinwong , Aug 6, 2014 :
    tornado can combine, just like the dragon ball
  16. Scann69
    No...those are recovery. Currently you device is with Stock. TWRP would be a better recovery to use....my personal preference.
    pgneo likes this.
  17. TimeFlies7
    TimeFlies7 , Aug 6, 2014 :
    ok...thx man
  18. kampuamee
    Go straight to page 1 if you haven't done so ;)
    Otherwise enjoy your stay here :D
  19. marcusyeo
    Eclair Aug 6, 2014
    marcusyeo , Aug 6, 2014 :
    These are recovery to flash the ROM. In computer terms,its the bios to flash the os.ROMS are like:slimroms,paranoidandroid
    pgneo likes this.
  20. Scann69
    Reading it alone might get confusing. Best to do it while you're reading it. Remember to back up if you do.
