170
Malaysia OnePlus Fan Club
  1. Jevoly
    Marshmallow Jul 13, 2014
    Jevoly , Jul 13, 2014 :
    Same as mine, expected delivery on July 18... Yay!!.. :cool:
  2. Jevoly
    U just registered with our MIS? U entered ur forum name as "Winston". U should enter "winstonngoh". Nvm, I've edited for u.
  3. xeNOS
    Gingerbread Jul 13, 2014
    xeNOS , Jul 13, 2014 :
    Haha.... thats the million dollar Q in this forum.
    Kenz78 likes this.
  4. Zeez
    Froyo Jul 13, 2014
    Zeez , Jul 13, 2014 :
    Cheers homie ;)
  5. Kenz78
    KitKat Jul 13, 2014
    Kenz78 , Jul 13, 2014 :
    This is a rough projection and prediction done by one of the fellow forumer based on these few days invite
    July 11 6000
    July 12 7600
    July 13 9000
    July 14 10000
    July 15 11,900
    July 16 13,000
    July 17 14,700
    July 18 15,500
    July 19 16,000
    July 20 18,000
    July 21 19,800
    July 22 21,000
    July 23 23,700
    July 24 24,000
    July 25 25,000
    July 26 27,000
    July 27 28900
    July 28 29000
    July 29 29,500
    July 30 30,000
    July 31 32,000
    Aug 1 34,000
    Aug 2 36,000
    Aug3 37,700
    Aug4 38,000
    winstonngoh likes this.
  6. kampuamee
    Lollipop Jul 13, 2014
    kampuamee , Jul 13, 2014 :
    Come across this thread:
    https://forums.oneplus.net/threads/updated-invite-rollout-plans-supervised.53878/
    Very close indeed.
    Kenz78 likes this.
  7. Zeez
    Froyo Jul 13, 2014
    Sounds promising
    If so, then let's hope that you gonna get it next Tue
    Kenz78 likes this.
  8. Kenz78
    KitKat Jul 13, 2014
    Let's hope most malaysian can get it, then we can start discussing about other thing like rooting mod and apps
    xeNOS likes this.
  9. blacksgsii2012
  10. Syeemoane
    Syeemoane , Jul 13, 2014 :
    this is good stuff, considered to post as sticky info at the first 1st post of this topic/thread.
    [GUIDE] OnePlus One - How to Unlock Bootloader, Install Custom Recovery and Root
    Information
    Rooting this device is actually quite a simple and easy process. Before you begin, it is recommended that you at least try to understand what each part of the process will do. Although this guide will elongate each step in order to show all of the details, the method used can be broken up into 3 main steps: Unlocking the Bootloader, Installing a Custom Recovery and finally Rooting. Each new step relies on the previous step to have been completed, and a basic summary of each part is:
    1. Unlocking Bootloader: Opens the door to the internal memory of the device to be written on to. This allows you to flash images onto the main partitions of the phone.
    2. Installing a Custom Recovery: A custom recovery is flashed onto the recovery partition of the device and overwrites the stock recovery that exists by default. Custom recoveries bring lots of functionality and give you the ability to perform wipes, install flashable zips, create full backups of your NAND (Nandroid backup), and various other features. An unlocked bootloader is needed to install a custom recovery.
    3. Rooting: You can gain root by either flashing via recovery a pre-rooted custom rom, or flashing a zip containing the SuperSU binaries. A custom recovery is necessary to do this.
    Oneplus One Toolkit [gui]
      • Unlock your device's bootloader
      • Lock your device's bootloader
      • Root your OnePlus One without installing a custom recovery
      • Flash CM11S and ColorOS
      • Install ADB drivers
      • Flash and custom recoveries
    Felix, sjhann and Jevoly like this.
  11. kampuamee
  12. Kenz78
    KitKat Jul 13, 2014
    German
  13. kampuamee
  14. Kenz78
    KitKat Jul 13, 2014
    They are strong in offense and defence. Brazil got their *** kick really hard
  15. shengchai
    Donut Jul 13, 2014
  16. leking19
    Cupcake Jul 13, 2014
  17. [A]ngellike
    Ice Cream Sandwich Jul 13, 2014
  18. Syeemoane
    sjhann likes this.
  19. L4ZYJIM
    Honeycomb Jul 13, 2014
  20. azrul
