Many issues since uninstalling Themer
  1. dj.barnwal
    Cupcake Oct 7, 2014
    dj.barnwal , Oct 7, 2014 :
    I recently got my OPO (16GB Chinese) and I updated it to CM 33R. Also midway while I was downloading updates I installed Themer app from the play store gave some permissions to the app and after sometime directly uninstalled it. Since then I am not able to use the home button i.e. the home button does not work at all, the status bar comes down but nothing happens when I click the top right icon which toggles more option by flipping. Connecting USB to PC nothing happens (except charging :/ ) The Home option from the settings is missing. I am newbie with all these things please help me.
  2. kinghanson99
    Honeycomb Oct 7, 2014
  3. shivkaranshah
    Ice Cream Sandwich Oct 7, 2014
    shivkaranshah , Oct 7, 2014 :
    I think you need a hard reset.
    Try clearing the cache, if it doesn't work hard reset.
    Themed works fine on mine, @kinghanson99 Themer is something much better than themes showcase.
  4. Jimit Shah
    Gingerbread Oct 7, 2014
  5. dj.barnwal
    Cupcake Oct 7, 2014
    Yah I did nothing seems to happen
    Sorry for being noob, how do I clear the cache?
  6. shivkaranshah
    Well, switch off your phone, now hold vol down+power together.
    You'll get a screen, use the volume buttons to scroll to the clear cache option and power button to select it.
    If this doesn't work, hard reset your phone bro.
  7. dj.barnwal
    Cupcake Oct 7, 2014
    Factory reseted.. Worked :D Thanks everyone
