3
marks on my 5t
  1. OnePlus OxygenOS
    Honeycomb May 20, 2018
    OnePlus OxygenOS , May 20, 2018 :
    the Spigen case is good, I tried using other thinner cases but ended up slapping the Spigen back on coz I like the grip that it offers...only issue is the full coverage tempered glass coming into contact with the sides [e]1f625[/e]
  2. Thanasis St
    Gingerbread May 20, 2018
    Thanasis St , May 20, 2018 :
    it would really help if you just spend 5 minutes every once in a while to clean the case and the phone...just whipe with wet cloth and nothing would really happen...care about your things and they will care for you too...
  3. rahulprajapat1993
    Cupcake May 20, 2018
    rahulprajapat1993 , May 20, 2018 :
    hey guys I bought op 5t in December 17 .I have been using it very cautiously and never dropped it,but yesterday I opened the back case and found that there have been so many mark of color removed from back area .I was shocked to see that. how can the company do to buyers like this. although the performance of the phone is gud but this phone seems like a pretty old phone if I remove the back case.guys plzzz tell me if the cover can be replaced by the company
  4. Triple_A
    Triple_A , May 20, 2018 :
    This isn't OnePlus's fault. The paint chipping is probably a result of dust accumulation which would not have happened if you had removed your cover and cleaned the back of the phone regularly. However, if you had been using the free silicone case that came with the phone, I believe OnePlus will change your back panel at their service centre.
  5. X1513001495748
    X1513001495748 , May 20, 2018 :
    Try to clean with soap water, alcohol or baking soda. In worst case, you can try thinner :D but it can also wash colour of you back :O
  6. TheRealGamer
    Lollipop May 20, 2018
  7. TiMiXx
