154
ROM
Marsh [CM13]
  1. azeez4901 Ice Cream Sandwich Feb 24, 2016
    azeez4901, Feb 24, 2016 :
    if you had F2F partition, nothing we can do.. flash cm nightly latest and flash Aaah rom
  2. wea3el Honeycomb Feb 24, 2016
    wea3el, Feb 24, 2016 :
    I think you need to be fast and enter settings>apps>enable system apps via three dots and give permissions to setup wizard.
    Did it helped?
  3. ajxellos Ice Cream Sandwich Feb 24, 2016
    ajxellos, Feb 24, 2016 :
    Nope, I just wiped data from recovery. Now it fine. :)
    Aaahh likes this.
  4. wea3el Honeycomb Feb 24, 2016
    Cool!
    @Aaahh maybe solutions for this kind of problems that can occur during installation should be written in the first post.
    Modem problem
    Setup wizard crashing
    pluscat and Aaahh like this.
  5. Xial Gingerbread Feb 24, 2016
    Xial, Feb 24, 2016 :
    This is "an Equalizer that was once as default equalizer since CM7 and it performs almost identical to beats audio. (Best features: Dynamic Compression & Bass Boost)"
    I personally prefer dsp manager :p
  6. hazycowboy Froyo Feb 24, 2016
  7. hazycowboy Froyo Feb 24, 2016
    hazycowboy, Feb 24, 2016 :
    i believe you are talking about the 02/21 nightly... even i was experiencing a modem problem.... wiped and reverted back to the stable 1.9.7 build.
  8. wea3el Honeycomb Feb 24, 2016
    No, I'm on stable but some people had some modem problems because of TWRP version they were using.
  9. ericstender Froyo Feb 24, 2016
    ericstender, Feb 24, 2016 :
    I had the same problem... Easy fix.
    1. Flash ROM
    2. Restart phone normally
    4. Go back to recovery
    5. Wipe
    6. Flash G apps
    7. Restart phone normally
    The phone gets stuck if you don't re wipe after flashing Gapps.
    Basically flash ROM and g apps separately and wipe before flashing Gapps again. Then you should be good.
  10. salimoneplusone Gingerbread Feb 24, 2016
  11. Aaahh Lollipop Feb 24, 2016
    Aaahh, Feb 24, 2016 :
    I had a feeling it was that old thing
    Yeah audio fx is the replacement
    Maxxaudio has bass boost and dynamic compression so we good
    @Slydelix has been busy
  12. Xial Gingerbread Feb 24, 2016
    Old but good !!! But okay x)
    I tried Maxxaudio but it was buggy so...
    @punto likes this.
  13. Aaahh Lollipop Feb 24, 2016
    Originally
    After a curtain update (don't remember which one), it became much better
  14. Xial Gingerbread Feb 24, 2016
    Ow okay I trust you :")
  15. Max.Mar Jelly Bean Feb 24, 2016
    Max.Mar, Feb 24, 2016 :
    I guess your problem has already been answered. But still I would share my thoughts & experience with you..I don't flash ROM & Gapps together coz of more chances it been struck in error. Flash ROM first & reboot to the system then before flashing Gapps & after flashing gapps always do a wipe & then reboot normally. Never had any issue by doing it. ;)
  16. @punto Ice Cream Sandwich Feb 24, 2016
    @punto, Feb 24, 2016 :
    tried v4a the latest one?
  17. Manav Bhagia Ice Cream Sandwich Feb 24, 2016
    Manav Bhagia, Feb 24, 2016 :
    @Aaahh , I'm running your beta ( 21st Feb ) , And it is stable and smooth as f* (I don't get the point of calling it Beta , though I know music widget is messed up , but still It's not a deal breaker for anyone , I think . Anyways as Your thread is open to suggestions , I wanted to suggest compiling of the ROM with Dragon Clang Tc by frap129 (he's the one who bought Polly to opo) and by Compiling your ROM with Dragon Clang Tc , you would be Implementing Polly , With a $#!+ load of krait and miscellaneous optimizations for our chip , and it would be AWESOME !
    Here's the link if you're interested : http://forum.xda-developers.com/android/software-hacking/llvm-clang-dragontc-future-t3318386
    Big fan, by the way :)
    &Thanks for your time reading this ! :)
  18. Aaahh Lollipop Feb 24, 2016
    @jgcaap you might be interested too
    Jole7, ravager12, yoshpe and 4 others like this.
  19. Elas Jelly Bean Feb 24, 2016
  20. timos Jelly Bean Feb 24, 2016
    timos, Feb 24, 2016 :
    I didn't have the time to maintain a full ROM since I'm going to school. But I can participate... ;)
    luukbernardes and Aaahh like this.
