154
ROM Marsh [CM13]
  1. salimoneplusone
    Gingerbread Apr 15, 2016
    salimoneplusone , Apr 15, 2016 :
    I would suggest flash mini gapps now on top again and then the option will be enabled...tested resolution :)
  2. SathiyXIX
    SathiyXIX , Apr 15, 2016 :
    So flash pico first then let it boot up then go back to recovery and flash mini? As just flashing mini results in Bootloop
  3. @punto
    Ice Cream Sandwich Apr 15, 2016
    @punto , Apr 15, 2016 :
    u can download the rest from play store too........
  4. salimoneplusone
    Not because of the bootloop ..this is also to get google now option enabled.
  5. TheJames
    Jelly Bean Apr 16, 2016
    TheJames , Apr 16, 2016 :
    ROM runs amazingly here. Never had GAPP problem. I'll assure all of you its worth the trouble. Everythings been great. Especially developer support.
    Loving 2.0
    @punto likes this.
  6. Aaahh
    Marshmallow Apr 16, 2016
    Aaahh , Apr 16, 2016 :
    I'm releasing another build before I add all the cool stuff because I don't have time to test them
  7. @punto
    Ice Cream Sandwich Apr 16, 2016
    @punto , Apr 16, 2016 :
    developer support is the best thing that i like in this rom...no other devs support this much... @Aaahh an awsum job u are doing here...
    without the cool stuffs? is the new build mostly will be of bug fixes?
  8. @punto
  9. Slydelix
    Slydelix , Apr 16, 2016 :
    Is there someone on this forums who is willing to do a little sacrifice to our dark lord chin chin
    I need someone to set blur intensity to 100%...
  10. sizzlingtycoon
    Froyo Apr 16, 2016
    Jole7 and @punto like this.
  11. @punto
    yes i know... but in case its a bad xposed module then it might crash ur phone then again u need to wipe things....
    ur point is absolutely right......but somethings baked in the rom arw better for stability than sideloading.....
    Jole7 likes this.
  12. Aaahh
    Marshmallow Apr 17, 2016
    Aaahh , Apr 17, 2016 :
    Current nightlies basically
    I won't because I don't like it in sense of design currently
    maybe if I figure out how to make it flow better
    Don't assume things, I'm different
  13. Shubh21
    Honeycomb Apr 17, 2016
    Shubh21 , Apr 17, 2016 :
    Try the dashboard app by CDT, search for it in the play store..
  14. prashant78
    Donut Apr 17, 2016
    @punto likes this.
  15. @punto
    Ice Cream Sandwich Apr 17, 2016
  16. vipertongn
    vipertongn , Apr 17, 2016 :
    I'm trying to do the camera mod, but upon using my phone terminal, none of the commands work.
  17. Aaahh
    Marshmallow Apr 18, 2016
    Aaahh , Apr 18, 2016 :
    Back on Marsh
    Will release an update soon with a lot of fixes
    Also moving away from Mega
    edgehab, Jole7, @punto and 2 others like this.
  18. Aaahh
    Yeah, it'll make a return really soon
    what is that?
    @punto likes this.
  19. Aaahh
    it's old, my bad
    I'm adding volume steps because itz easy
  20. Alex_Saiwala
    Donut Apr 18, 2016
    Alex_Saiwala , Apr 18, 2016 :
    Thank you, build from the 10.04 - is already perfect! Expect even better!
