154
ROM Marsh [CM13]
  1. jgcaap
    Ice Cream Sandwich May 6, 2016
  2. Aaahh
    Marshmallow May 6, 2016
    Aaahh , May 6, 2016 :
    Oh no i was talking about @Slydelix
    I cloned your branch cm-13.0s and renamed it to cm-13.0 for a script I added to the build system. Its all good now, theres no need for you to change anything
  3. Alex_Saiwala
    Donut May 6, 2016
    Alex_Saiwala , May 6, 2016 :
    OK, guys, after so many changes in cm-weather-related, what need to do to weather again appeared in the notification bar?:grin::hearteyes::sunglasses:
    Thanks very much!
  4. Slydelix
    Jelly Bean May 6, 2016
    Slydelix , May 6, 2016 :
    Thats a really good question... I was wondering the same....
    Alex_Saiwala likes this.
  5. Aaahh
    Nothing
    We be waiting on cm now.
  6. suryachandranr1978
    Gingerbread May 7, 2016
  7. Pahapoika91
    Ice Cream Sandwich May 7, 2016
    Pahapoika91 , May 7, 2016 :
    @Aaahh @Slydelix maybe next stable build could include mods from cos 13, (Is that possible?)quickboot and some audio tweaks.
    Etc for build.prop
    audio.offload.buffer.size.kb=128
    audio.offload.pcm.24bit.enable=true
    audio.offload.pcm.32bit.enable=true
    audio.offload.pcm.64bit.enable=true
    htc.audio.swalt.enable=1
    htc.audio.swalt.mingain=14512
    htc.audio.alc.enable=1
    persist.audio.SupportHTCHWAEC=1
    ro.config.hw_dolby=true
    ro.config.hw_dts=true
    Also @jcgaap you should include possibility to change charge rates, overclock/underclock cpu,undervolt,more shedulers (Sio,zen row,trinpdroid)readahead buffer, display input boost,Swapiness.
    Thanks.
    Jole7 likes this.
  8. Aaahh
    Marshmallow May 7, 2016
    Aaahh , May 7, 2016 :
    done
    thanks!
    quickboot is gone
    are those from cos13 tho or elsewhere?
    Jole7 likes this.
  9. Alex_Saiwala
    Donut May 7, 2016
  10. Aaahh
    its not temporary
    in the settings
  11. Phipleton
    Cupcake May 7, 2016
    Phipleton , May 7, 2016 :
    I just flashed the latest build (clean flash). After this typical "Android is being started... 1 of 119 apps is being prepared" pop-up it just reboots... Then it's stuck in a boot loop... After turning it off and on again, same thing but this time it said "1 of 20 apps". After that boot loop again.
    So I wiped again and rebooted and after that it prepared it said "1 of 40 apps is being prepared"... wtf? I'm on F2FS is that a problem?
  12. Aaahh
    Yeah you had apps and wiping data removed them
    It shouldn't be, but it might be because cm did just test something for that and then revert it. In any case the next build should be better
  13. Phipleton
    Cupcake May 7, 2016
    Yea but it still went back into the boot loop and I cannot use the rom.. that's the problem for me.. That the amount of apps changes every reboot is just a weird thing I noticed.
    Edit: Hmm just can't get it to work. Is it maybe xposed or supersu causing issues?
  14. Aaahh
    Are you flsshing those before it boots?
    Yes
  15. auerbach
    Honeycomb May 7, 2016
    auerbach , May 7, 2016 :
    I know i should not ask for ETA
    but i'm done with cos after 1 month
    should i flash current beta builds or wait marsh 2 stable ?
  16. Aaahh
    Releeasing stable today
    Waiting on buddy to build
    yoshpe, auerbach and suskisunami like this.
  17. Slydelix
    Jelly Bean May 7, 2016
  18. suskisunami
  19. auerbach
    Honeycomb May 8, 2016
  20. Aaahh
    Marshmallow May 8, 2016
