154
ROM Marsh [CM13]
  1. Tarfex
    Ice Cream Sandwich May 9, 2016
    Tarfex , May 9, 2016 :
    Why did they take quickboot out. I remember having it when i first got the phone
  2. Alex_Saiwala
    Donut May 9, 2016
    Alex_Saiwala , May 9, 2016 :
    Strangely... Update to the stable version, i, for some reason, lost the legendary smoothness of the Marsh, particularly when opening apps and scrolling...
    Maybe there is a way to flash clean?
  3. EdLikesBeds
    Gingerbread May 9, 2016
    EdLikesBeds , May 9, 2016 :
    Definitely recommend clean flash with this awesome stable build. So smooth. If you downloaded the OTA it will be in /sdcard/cmupdater and go to twrp to clean flash like usual.
    Alex_Saiwala likes this.
  4. Aaahh
    Marshmallow May 9, 2016
    Aaahh , May 9, 2016 :
    Included the modems and other
    I noticed you have to flash the rom twice because it rebootd before everything flashes if it has to wipe ddr
    I didnt know that bug exsisted
    The shourcuts work
    I'm releasing and update again soon
  5. k.kost9
    Eclair May 9, 2016
    k.kost9 , May 9, 2016 :
    Clean flash latest stable, Pico gapps, su.
    Audio fx crash on boot and won't work.
  6. Aaahh
    Thats what i thought to but for some reason the zip from my pc and from ota aren't the same
    It doesnt make sense
    EdLikesBeds likes this.
  7. Aaahh
    Yes only you.
    I see thus bug on half the ops
    Why half, i dont know.
    It should but i noticed ota would brake sometimes
    Yeah
    2 is newer, and i built it
    Im fixing the gapps problem later today
    Qualcomm abandonment
    Ah seriously
    It might be audio effects, check if that works
    It suddenly quit on my and i dont know why
    New stable buuld soon anyways
    Yup
    I fd up the build
    New build today by my buddies pc. Mine is in bad shape.
    Alex_Saiwala and ElRobertson like this.
  8. Vadomata
    Jelly Bean May 9, 2016
    Vadomata , May 9, 2016 :
    How fast is this os like does it take long to open applications and switch between them? I don't play but smooth scrolling and application load is a must, also does this have Qualcomm snapdragon camera kernel?
  9. @punto
    @punto , May 9, 2016 :
    then sud we wait? coz few peoples are saying that the battery life aint that great and smoothness is kinda missing... i am on 2.0 beta and its damn smooth(with bugs such as battery life , gallery etc..u know..)...
  10. @punto
    dude this is one of the best rom for oneplus one..... moreover the help that Aaahh gives to each of our comment is dope...... u can wait a lill for the next "more stable and smoother" release.....
    Tarfex, Jole7 and Alex_Saiwala like this.
  11. yoshpe
    yoshpe , May 9, 2016 :
    dont know about those rummors... i just came back from nuclear and Marsh is better then ever IMO.
    its just out, so cant say much as for battery life, but if something, its better (for me) then last few beta builds
    Jole7 and @punto like this.
  12. Alex_Saiwala
    Donut May 9, 2016
    Thank you very-very much for the quick reply!!!
    But I have tried to flash clean, to be honest, in different ways: on top of the old build, over a nightlie with wipe and without wipes - in general - according to various, but I have failed (Error Settings wizard, if i select a language)
    And what kind of OTA are you talking about? I downloaded the firmware from the link in the first post...
    Can it is necessary to return again on twrp version 2.8.6...х
    2 years with a phone and custom ROMs and very confused...
    Maybe I'm doing all not right (panic):(
    @Aaahh - thanks for reply! You are the best, guys!
    Jole7 likes this.
  13. jpatches
    Froyo May 9, 2016
    jpatches , May 9, 2016 :
    Sorry if redundant, but I can't find the search thread option under the new layout. Is there a way to get rid of the root symbol in the status bar?
    BTW thank you for your continuing work on this great rom!
  14. suskisunami
  15. Alex_Saiwala
    Donut May 9, 2016
    Clean or dirty?;) then write for us how it went
    suskisunami likes this.
  16. suskisunami
    suskisunami , May 9, 2016 :
    I'm going clean this time :rolleyes: ok then I post my feedback :D
  17. EdLikesBeds
    @Alex_Saiwala well Aaahh did say he's going to release another stable build today so wait until then. Stable builds are OTA so go to Settings > about > cm updates. Download it. Don't install from there if you plan to clean flash. The OTA update zip is at /sdcard/cmupdater. Clean flash in twrp with that zip ans pico gapps and it should work perfectly.
  18. resporival
    Honeycomb May 9, 2016
  19. suskisunami
    I'm having a lot of issues ...first was the installation setup stopped,then when I managed how to get through, I don't have mobile data ... any thoughts ?
  20. Alex_Saiwala
    Donut May 9, 2016
    Thank you very much for reply!
    however, it is still strange that I was not able to install the previous stable build..
    I did not understand why: build downloaded without problem, twrp 3.0 , gapps always Pico, wipes are all done... hm, why...oddity
    Thanks again for support and reply!
