154
ROM Marsh [CM13]
  1. Aaahh
    Marshmallow May 9, 2016
    Aaahh , May 9, 2016 :
    Under status bar in settings
  2. suskisunami
    Gingerbread May 9, 2016
  3. Alex_Saiwala
    Donut May 10, 2016
    Alex_Saiwala , May 10, 2016 :
    useless! I wrote about this a bit above in his post
  4. Aaahh
    Marshmallow May 10, 2016
    Aaahh , May 10, 2016 :
    I need logcat
    But wipe cache or just click okay
    If no dice, wipe data
    Alex_Saiwala likes this.
  5. Aaahh
    flash it again
    If that doesnt work flash a recent cm nightly then marsh
    this shouldnt happen again from now on
    Search is from gapps
    status bar settings for root
    I'm shrink the size of the rom at the cost of less performance. You guys want this...
    suskisunami likes this.
  6. Aaahh
    yes
    infact up until today the camera was bundled
    i replaced it with another camera that is the same but is easier to use ui wise
    Laamapalmu and Alex_Saiwala like this.
  7. Alex_Saiwala
    Donut May 10, 2016
    how correctly to make logcat if more than the choice of language, I can't boot?!)
    ps: thanks for update 05.10 !!!
  8. @punto
    Ice Cream Sandwich May 10, 2016
    @punto , May 10, 2016 :
    if its going to lower performance then plzz dont do that....
    Tarfex, Jole7 and yoshpe like this.
  9. Alex_Saiwala
    Donut May 10, 2016
    I was not able to dirty updated from 05.08 to 05.10
    stuck on downloading android...
    (last open Pico)
    upd: returned old gapps and updated without errors
    (btw, date of newest build left 05.08!)
    mrblackthorne likes this.
  10. Alex_Saiwala
    Donut May 10, 2016
  11. mrblackthorne
    Eclair May 10, 2016
    mrblackthorne , May 10, 2016 :
    Clean flash and I'm stuck in Boot Loop. Coming from a CM13 Snapshot. It only optimizes 25 apps rather than the 100ish it usually does.
  12. aakash0606
    Honeycomb May 10, 2016
    aakash0606 , May 10, 2016 :
    @Aaahh I'm on CM 13 latest snapshot. Waited long for Marsh stable 2.0. Should I wait for your next stable release for 2.0? P.S. I don't mind waiting for another week.
  13. suryachandranr1978
    Gingerbread May 10, 2016
    Aaahh likes this.
  14. suskisunami
    suskisunami , May 10, 2016 :
    i don't have time to read every post in the thread , if you have , good for you . if I have issues I just post, if someone tell me the fix in "X" post i'll see it.. I think I don't need that kind of words to me..
    Edit: @Aaahh tonight i'll try it mate, thx for the help ! :rolleyes:
    Jole7 likes this.
  15. Alex_Saiwala
    Donut May 10, 2016
    Hey, buddy, I'm afraid you are incorrectly interpreted my post! it is not about making you read the whole thread, but about solidarity with you, that even after you install exactly the nightlie firmware not installed. OK?!)))
    But, glad you got it!)
  16. vu_nam
    Cupcake May 10, 2016
    vu_nam , May 10, 2016 :
    I downloaded the lasted version 20160510 but after fresh installing, the version is 20160508 and the 20160510 update could not be downloaded. What's wrong here?
  17. @punto
    which gapps? use pico
  18. suskisunami
    ok mate :rolleyes: , you need to know some words when we write can be misunderstanding :D
  19. bright_wal
    bright_wal , May 10, 2016 :
    Has the camera gotten any better or is it the same from the cm13 snapshot, thanks for replying in advance!
  20. Alex_Saiwala
    Donut May 10, 2016
    the consensus:D
