154
ROM Marsh [CM13]
  1. Aaahh
    Marshmallow Feb 26, 2017
    Aaahh , Feb 26, 2017 :
    IM dead
    Okay time read wat u wrote
  2. Pahapoika91
    Ice Cream Sandwich Feb 26, 2017
    Pahapoika91 , Feb 26, 2017 :
    You seem alive to me.
    It's oneplus who's being idiot.
  3. Prinze Martin
    Prinze Martin , Feb 26, 2017 :
    That's the June 20th build I guess. It's fixed in the June 22nd build (link is in the OP). Try that
  4. crisis-trustee
    Gingerbread Mar 27, 2017
    crisis-trustee , Mar 27, 2017 :
    Where and how I can take this pro form?
    Thank you in advance!
    Good luck!
  5. crisis-trustee
    Good luck!
  6. prashant78
    Donut Apr 18, 2017
  7. Aaahh
    Marshmallow Apr 19, 2017
  8. Pahapoika91
    Ice Cream Sandwich Apr 19, 2017
    Prinze Martin likes this.
  9. luxuskamel
    Lollipop Apr 25, 2017
    luxuskamel , Apr 25, 2017 :
    1x A
    2x a
    2x h
    Just remember the amount of letters with the beginning of the Fibonacci numbers ;)
  10. hazzavg
    KitKat May 9, 2017
    hazzavg , May 9, 2017 :
    You mean 1 then 2....
  11. sam5656
    Donut Jul 16, 2018
    sam5656 , Jul 16, 2018 :
    Hi I'm trying to install the stable build which is 2.0 for greater battery life flashing the 2.0 ROM is enough or any other gaps is required to flash, by the way can you suggest me which of better battery ROM because i downgraded to 44s still it drains 1% power hour still my phone is in sleep mode thank you.
  12. Prinze Martin
    Ice Cream Sandwich Jul 18, 2018
    Prinze Martin , Jul 18, 2018 :
    The June 22nd build is stable by far, if not try the earlier version 1.7 and gapps is required, it's not built in. I don't own the device anymore so no idea on a good ROM right now. AEX 8.1 must be a good option :)
