154
ROM Marsh [CM13]
  1. Aaahh
    Marshmallow Dec 29, 2015
    Aaahh , Dec 29, 2015 :
    It looks the same in a way, just beautiful and heck of a lot better code
    2 weeks or more
    Try a different scheduler
  2. olbatar
    Gingerbread Dec 29, 2015
    olbatar , Dec 29, 2015 :
    Well as I see the icon app are bigger on google now launcher that weird and ugly...
    Aaahh likes this.
  3. Red5PlusOne
    Cupcake Dec 29, 2015
  4. @punto
    Ice Cream Sandwich Dec 29, 2015
    @punto , Dec 29, 2015 :
    i am not using trebuchet neither soft keys...... still reboot occurs......... @Aaahh
    Aaahh likes this.
  5. @punto
    can anybody test whether viper4android drastically degrades battery life or not? please use,test then rply ......
    thnk u
  6. butaixyz8016
    Honeycomb Dec 29, 2015
    butaixyz8016 , Dec 29, 2015 :
    So first I have to flash the full rom then firmware and then gapp? I m flashing it for the first time also which gapps should I prefer??
    Ayuvelo likes this.
  7. olbatar
    So do as I already advise before to search where is the problem for you.
  8. prem.kansara
    Jelly Bean Dec 29, 2015
  9. @punto
    i believe its the scheduler .... coz the reboot only occurs when i am using the phone ...... when not using, no reboot occurs...
    Aaahh likes this.
  10. olbatar
    Weird that some gets no reboot, others when using apps, and others with launcher...
  11. jibran9520
    jibran9520 , Dec 29, 2015 :
    Bug:
    Massive lag/crash/black screen when uploading video to whatsapp often, it just lags, takes long, blacks out for few seconds, then uploads normally after. Pretty annoying. Works fine after 5-10sec.
  12. CaBooSe
    Aaahh likes this.
  13. Ayuvelo
    Ayuvelo , Dec 29, 2015 :
    I liked Blisspop the most but since it was probably the cause that my phone got completely annihilated (and its not on the list), probably PA (even though battery wasn't really good)
    @Aaahh please don't integrate to mucht trash like music players or so as most of us prefer something else... Your ROM is a great base for installing the things one likes by himself :)
  14. Aaahh
    It is, its for the batter
  15. Aaahh
    It isn't
    The reason I don't want to add that is because if I do, if gets harder to remove or go to stock
    I think your right!
    How big is your wallpaper size data wise
    Yeah, this is all pointing to the scheduler
    I now recommend this.
    Get me a link please
    That's the point, but I may add pie and some settings
    GUYS, TEST OUT CHANGING THE SCHEDULER. I have tons there, try something other than zen.
  16. anzi2001
  17. Saurabh Kulkarni
    Eclair Dec 29, 2015
    Saurabh Kulkarni , Dec 29, 2015 :
    Hey @Aaahh is there ANY way (whether Xposed or anyhing) to bring back Navbar targets?? I absolutely can't live without Swipe up to turn screen off target but I am addicted to that Marshmallow app animations too :p I searched and flashed all MM roms but none of them had that. Thank you :)
  18. ab123321
    ab123321 , Dec 29, 2015 :
    Will be included in next nightly :p.
    P.S. @Aaahh, the problem was JUST IN OTHER PARAMETERS' ORDER (or / in the ends of paths:D). I used latest dtbTool from CM repo without any changes.
    Code:
    ./dtbToolCM -2 -s 2048 -o dt.img -p scripts/dtc/ arch/arm/boot/
    instead of my wrong
    Code:
    ./dtbToolCM -2 -o dt.img -s 2048 -p scripts/dtc arch/arm/boot
  19. Aaahh
    I like the swipying up thing, but guys a port will be basdly integrated and I wish I was that good of coder to make that without horribly butchering the current code.
    anzi2001 likes this.
  20. Aaahh
    On the lock screen?
    Or like pie?
    And if you do find a xposed for lollipop or marshmallow, link me.
    Also, any LP rom that had that?
    But you don't get to use the sony one... Lololol k
