16
ROM Marsh [CM13]
  1. Aaahh
    Marshmallow Mar 9, 2016
    #41
  2. RossThompson96
    Honeycomb Mar 9, 2016
    RossThompson96 , Mar 9, 2016 :
    Have you thought of posting to XDA, OnePlus forums layout just isn't nice
    #42
  3. Aaahh
    Marshmallow Mar 17, 2016
    Aaahh , Mar 17, 2016 :
    Some mod wouldn't shut up and locked my opo thread because my sources werent up then
    #43
    RJ Murdok likes this.
  4. Bounze
    Honeycomb Jun 1, 2016
    Bounze , Jun 1, 2016 :
    I can't install it, tried both clean and dirty flashing from official cm13 nightly
    #44
  5. hazzavg
    KitKat Jul 10, 2016
    hazzavg , Jul 10, 2016 :
    I'm coming from 0129 and am going to flash 0510
    I had literally forgot to update my phone in that time but hey
    I see that there's a firmware update from 0125 which is up to 4.0.1 and I'm on 3.0 so I'm assuming I'm going to need that
    I'm just downloading a more recent gapps as again mine is stupidly old
    Is there anything else to know that's happened in the last few months as I've been off the custom ROM scene completely
    #45
  6. DrJMun
    Jelly Bean Jul 10, 2016
    DrJMun , Jul 10, 2016 :
    I've had Marsh now for a couple of days and I'm disappointed with battery performance. I was getting much better performance using Sultan. I'm using the same things: Xposed, Amplify, Greenify, PowerNap and always have my device on PowerSave mode. I use GSAM battery to monitor battery usage and it's using 1%/hr., under Sultan (12) I was getting 0.6%/hr. I'll keep using it for the rest of the week to see if it improves. Other than that I like it.
    (I accidentally posted this in the OP2 thread)
    #46
  7. DrJMun
    Jelly Bean Jul 15, 2016
    DrJMun , Jul 15, 2016 :
    I've been trying Marsh out for a week, I was previously with Sultan. So far I'm disappointed with battery life. Using 1%/hr (I was getting 0.5%/hr using Sultan) In trying to chase this down I find that WiFi is always active (yes I checked to see it's switched off and the Advanced option of: Keep WiFi on during sleep is set to NEVER).
    Currently running: Marsh 2.0 CM version13.0-20160620
    I've rebooted several times. Cleared caches.
    Also I keep getting "XXX has stopped working" errors.
    Seeking suggestions.
    If I cant get this resolved I'll go back to Sultan.
    #47
  8. DrJMun
    Jelly Bean Jul 16, 2016
    DrJMun , Jul 16, 2016 :
    OK, I gave Marsh a week and finally had to restore to my previous version of Sultan that I had backed up. Just too many problems. In addition to the ones I listed above I found it was have GPS location problems as well.
    I'll give it another shot if/when they make a more functional update.
    #48
  9. Nyan_
    Jelly Bean Jul 26, 2016
  10. Nyan_
    Nyan_ , Jul 26, 2016 :
    Yeah I don't have a opx, kinda hard to fix and test
    #50
